Issue 23
The Left Thigh Put the detail (23B) in place on the inner thigh as shown in picture 2.
Turn the thigh plate over and place the top of the left leg assembly over the plate onto the four posts as shown in picture 3, and secure with 4 x EM screws, picture 4. Picture 5 shows the completed assembly for this issue.
Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 24
The Left Thigh
Take the left hip plate and carefully fit it onto the assembly part of the left leg as shown in picture 2.
Turn the assembly over and secure it with 2 x EM screws as shown in picture 3.
Picture 4 shows the complete assembly for this issue.
Issue 25
The Left Thigh
Take the part 25C, the left hip ball joint and place into the external support 25A as shown in pictures 2 and 3. Now prepare the internal support 25B and place the two friction blocks 25D and 25E in place as shown in picture 4. Picture 5 shows them in place.
Carefully place this assembly onto the hip joint you prepared a moment ago and secure with 3 x EP screws, picture 6.
Place the finished hip joint onto the left hip plate you assemble in issue 24, picture 7. Secure it in place using 2 x EP screws as shown in picture 8.
Picture 9 shows the complete assembly for this issue.
Issue 26
The Left Thigh
Take the upper thigh 26B and attach one of the three connectors with a CP screw, picture 2. Take another connector and secure it in the same way as shown in picture 3.
Take the upper thigh assembly 26B and the lower thigh 26A and place them together as shown in picture 4. Turn the assembly over and join the two parts by placing a CP screw in the already placed connector into the tab on the lower thigh, picture 5. Take the third connector and secure it with 2 x CP screws as shown in picture 6.
Picture 7 shows the complete assembly for this issue.
