Is there an answer to this problem? Options
goddo
#1 Posted : 29 February 2024 15:41:29
I am currently on my third of the model trams that are around and I have a constant problem which hopefully(?) occurs on other areas of modelling.
The windows are just perspex sheet glued the window frames.
My problem is that no matter how late in the build I leave the window, they get coated with dust and all sorts. I can't cover them over inside as they gradually become inaccessible.
I would love to install them last but can't see a way of doing that.
All ideas and comments grateful accepted.
#2 Posted : 29 February 2024 21:54:25
Hi Chris.
The only thing I can think of would to use some micro sized styrene quadrant moulding strips painted black to simulate rubber 'gaskets' and to line the window openings but only on the inside (to start with). Then you could leave the window glazing off until the very end and finally fit them in position and secure them in place with another styrene quadrant on the outside possibly glued in with one of the clear canopy glues which won't affect the clear acetate.
Other than that you could make sure the window acetate fits exactly into each position and pre-glue the quadrants on both sides of the acetate before gluing the whole thing into the cut out using the same canopy glue.
Windows are never easy!BigGrin
Robin.
goddo
#3 Posted : 01 March 2024 01:22:45
Hi Robin,
Thanks for the reply but I must admit that I had to read it about three times before I fully understood it! BigGrin BigGrin
It now makes sense and I shall run a few experiments to try and emulate your suggestions.
#4 Posted : 01 March 2024 22:23:16
Hi Chris!
I'm not surprised you had to read it a few times - so did I after I'd written it!BigGrin
I thought at the time a little diagram would have made it clearer, the trouble is I can only log on to the forum with the windows 10 computer but all my design stuff for the diaries can only be done on the old windows xp one! The Corel Printhouse program I use won't function on 10 and it's successor Corel Draw is horrendously expensive still (even second hand!)Blink
Never mind, hopefully you've got the gist ok and I'm looking forward to see how it turns out!BigGrin (Then I'll know if I can use it in the future!!)LOL
Best of luck!
Robin
goddo
#5 Posted : 03 March 2024 14:19:57
Hi Robin.
It's OK thanks. Honestly, it all became very clear.
In this instance gaskets on the rear of the window openings won't really work but I have a cunning plan (as Baldrick would say).
I intend to start a build diary on this so, if my plan works, I'll show you what I did.
Chris.
#6 Posted : 03 March 2024 17:37:57
Hi Chris, BigGrin
The attraction of dust sounds like a static electricity issue and I`m sorry but I don`t know the answer. The one thing that I am sure of is, that I will be watching the build diary as I love these tram kits.
Bring it on I`m ready. Cool Love Cool
(Derek) Admin
ExDalek
#7 Posted : 04 March 2024 22:55:22
Hi,
You can get anti static sprays that clear coat plastic, if that helps. I have never used it myself, but you never know!
There is also anti static cleaner for perspex, but it only lasts a month, but I guess that would be okay once the windows are in?
Mark.
"I remember it like it was yesterday. Of course I don't really remember yesterday."
goddo
#8 Posted : 05 March 2024 11:52:43
Hi Mark,
Thank you for the input but I have tried anti static spray and it doesn't stop some of the "stuff" floating around while the model is in construction.
I have got some different anti static cloths coming today but don't hold much hope.
#9 Posted : 05 March 2024 20:05:54
Hi Chris.
The other 'brilliant idea' I had was to use that clear non adhesive 'static' film like you get on all new gizmos with an LCD screen or similar, the stuff that you have to peel off before use. You can get a similar product on ebay for applying to windows to either make them translucent for privacy or to cut out the UV coming through the glass.
The obvious problem is that it might be fine for the outside but might be very difficult to remove again from the inside after the roof goes on!Blink
Robin
goddo
#10 Posted : 06 March 2024 20:09:48
Plymouth57 wrote:
Hi Chris.
Robin
Hi Robin,
Appreciate your time giving this windows some thought
The real problem is the insides of the perspex when they are inaccessible.
It's a good thought with the film that you mentioned. A bit too late for this model now but I shall certainly think about using it in the future.
This page was generated in 0.187 seconds.
