Optimus Prime Official Build Pack 7 Options
#1 Posted : 27 January 2024 13:23:54
Issue 27
Assembling the Torso
Picture 1 shows the contents of the parts for this issue.
Push in part 27C into the holes as shown in pictures 2 and 3. Do the same on the opposite side with part 27D, picture 4.
Next, insert the pelvic plate support into the lower central hole on the torso as shown in pictures 5 and 6.
Turn the assembly over and screw in an IP screw as shown in pictures 7 and 8.
Picture 9 shows the complete assembly.
That completes the assembly for this issue until next time, so sit back and enjoy a cup of tea, final picture.
#2 Posted : 31 January 2024 20:06:15
Issue 28
Assembling the Pelvis and Torso
Picture 1
Take the bar of the lower fixed connection and the pelvis from issue 25, picture 2. Place it into the pelvis as shown in picture 3, then cover the bar with the bracket securing it with 2 x BM screws, picture 4.
Next, take the upper fixed connection with its two brackets and 4 x WP screws, picture 5. Place the bracket over the bar of the upper fixed connection and secure with the 4 x WP screws.
Note the orientation of the bracket to the fixed bar, picture 6.
Picture 7 shows the complete assembly for this issue.
#3 Posted : 06 February 2024 10:18:02
Issue 29
Picture 1
Insert the pin on the right torso detail (29A) into the hole in the bracket (29E) and push all the way in, picture 2. Note - The pin is ā€œDā€ shape and will only fit one way. Do the same to the left torso detail, picture 3.
Take the assembly that you completed in issue 24 and fit one of the ball joints as shown in picture 4. The ball joint will only fit one way. Turn the assembly over and secure it with a DM screw, picture 5.
Now take the assembly from issue 28 and the last ball joint and fit into place as shown in picture 6. As before, turn the assembly over and secure it with a DM screw, picture 7.
Picture 8 shows the complete assembly for this issue.
#4 Posted : 11 February 2024 19:12:54
Issue 30
Picture 1
Take the detail 30D, this has the larger tab of the two parts, picture 2. Put an MP screw in the detail far enough so that the piece enters the notch on the left-hand side of the pelvis, pictures 3 and 4.
Tip: When fixing the screw, it can be a tight fit and you may come to some resistance to place it any further. Do not force the screw as you may break the part. If this happens unscrew it and then screw it back in, you may have to do this a couple of times.
Now take the other detail, the one with the smaller tab as shown in pictures 5 and 6. The easiest method to attach this part is to thread the screw first using the method in the tip above. This will make it much easier to attach once you have done this, pictures 7 and 8.
Snap together parts 30F into 30A as shown in pictures 9 and 10. Next, attach 30E as shown in pictures 11 and 12. Do the same with the left torso detail. Picture 13 shows the two assemblies complete.
Snap in the two assemblies into the central torso as shown in pictures 14 and 15. Take the bracket detail from the previous issue and snap into place as shown in picture 16, followed by the other detail on the opposite side. These will only fit one way as they have a ā€œDā€ shaped pin.
Picture 17 shows the complete assembly for this issue.
#5 Posted : 11 February 2024 20:02:10
Issue 31
Picture 1
Take one of the lower torso supports and fit into the left side of the pelvis as shown in pictures 2 and 3. Take one of the bolts and attach a spring washer and a washer as shown in picture 4. Attach it as shown in picture 5. Take the right side of the pelvis and fit the torso support in the same way as before, picture 6. Secure it using the bolt, spring washer and washer as before, picture 7.
Fit the two halves together, picture 8, and secure with 4 x IM screws, picture 9.
Take the pelvis assembly and fit it to the back of the pelvis, picture 10, securing the assembly with 4 x IP screws, picture 11.
Snap in the detail parts into the front torso as shown in pictures 12 and 13. Next, attach the front torso into the centre torso and attach with a KP screw, pictures 14 and 15.
Put the centre hole of the upper fixed connection onto the pin of the centre torso as shown in picture 16. Secure it using a VP screw, spring washer and washer, picture 17.
Attach the remaining two halves together using 6 x KP screws as shown in pictures 18 and 19.
Picture 20 shows the complete assembly for this issue.
