cast model parts prep. Options
goddo
#1 Posted : 31 January 2024 12:38:09
I wonder if anyone can offer me some advice about preparation of cast alloy parts for my model?
There are numerous parts of varying size, weight and delicacy.
I have tried soaking them and giving them a scrub in nail varnish remover and then a coat of etch primer but as soon as I move them or attempt to paint them, the primer flakes off in patches.
I then tried "ordinary" primer paint with similar results.
Any tips would be appreciated.
Chris.
#2 Posted : 31 January 2024 17:03:31
Chris.
Hi Chris have you tried etched primer. You can get them from motor parts shops.
Hope this helps
Martyn
#3 Posted : 31 January 2024 20:04:41
Hi Chris.
When you say 'ordinary primer paint' was that acrylic or car spray type? If it was acrylic I would suggest trying a standard matt grey enamel like Humbrol etc, that usually sticks to pretty much anything.
Best of luck!
Robin.
GilShapley
#4 Posted : 31 January 2024 22:14:00
I use a standard grey primer spray from Halfords then apply my Acrylic Spray/brush paint
ThumpUp ThumpUp
Current Build:-
#5 Posted : 31 January 2024 22:54:46
Hi Chris, BigGrin
Like Gil I use the Halfords rattle cans.
They work out cheaper as they are quite large in volume and you can get one for plastic as well as the one for metal. (In Grey)
Don`t forget to give it a darn good shake before every use and invert the can and give a very short blast when you`re done as that stops the nozzle clogging up.
Only down side is the fumes. Use in a well ventilated place. I have a sealed unit spray booth, so combustible fumes don`t get to the electric motor.
Hope along with all the other tips that you get sorted.
(Derek) Admin
goddo
#6 Posted : 01 February 2024 00:30:32
Thank you gents.
The "ordinary" primer I referred to is acrylic. I have already tried etch primer which seems no more efficient.
Might pop into Halfords and get a couple of rattle cans to see if that does the trick.
This page was generated in 0.114 seconds.
