Robocop Official Build Pack 4 Options
#1 Posted : 04 January 2024 19:45:47
Issue 11
The Right Arm
Picture 1
shows the contents of this issue.
Place the side cover in the hole on the arm as shown in pictures 2 and 3.
Next, insert the lower forearm over the wrist joint, picture 4.
Note: The lower forearm lines up at the back and will only fit one way. Use a little pressure to fit as shown in picture 5.
Take the hand assembly you completed in issue 4, picture 6, and remove the magnetic hand guard. Slightly loosen the four screws on the hand as shown in picture 7, this will allow the hand to be pushed onto the joint with a little pressure. Once on, tighten the four screws again and place the hand guard back on as before.
Pictures 8 and 9 shows the final assembly for this stage.
That completes this issue.
#2 Posted : 09 January 2024 22:15:01
Issue 12
The Right Shoulder Joint
We now start on the right shoulder joint. This issue just has a few parts to assemble this time around, and shouldn’t take too much effort, but the arm starts have some serous weight to it.
Place the circular detail into the shoulder as shown in picture 2.
Fit the two shoulder covers over the shoulder and secure with 4 x AM screws, picture 3 and 4.
#3 Posted : 14 January 2024 15:54:03
Issue 13
The Left Foot
Picture 1
Insert the ankle through the lower part of the foot with the ball joint pointing downwards, pictures 2 and 3. Turn the assembly over and the top of the pin should be facing left as shown in picture 4.
Now place the friction block, the larger of the two, into the base joint, pictures 5 and 6. Now take the smaller friction block and fit it over the first friction block as shown in picture 7 and 8.
Turn the assembly over and place it over the ball joint you assembled under the foot and secure it with 4 x CM screws as shown in picture 9.
Picture 10 shows the completes assembly for this issue.
#4 Posted : 16 January 2024 19:45:31
Issue 14
The Left Foot
Picture 1
Place the spring onto the post and fix in place with a CM screw as shown in picture 2.
Fit this assembly into the assembly from issue 13 securing it with a CM screw. The assembly should look as shown in picture 3.
Now take the toe cap, along with a CM screw, picture 4, and place the screw into the centre lug as shown in picture 5. Note: do not tighten the screw just yet.
Insert the toe cap into the main part of the foot and pull the spring around the screw, as shown in picture 6. Once in place tighten up the screw to stop the spring end from moving.
Picture 7 shows the complete assembly for this issue.
This page was generated in 0.145 seconds.
