Mizzen Mast problem issue 54 Options
Deepseacodmaster
#1 Posted : 12 October 2011 12:46:31
Hi All
At some point during my build I must have made a basic mistake which has caused my mizzen mast to be about 1.5 mm off the vessels center line.
When I ensure the 8mm dowel fits into the mizzen mast hole, and goes all the way to the bottom, you'll find it easier to insert if you sand a bevel on one end. (as per MR T's Official build instructions)
The mast is not vertical and is offset see photos
My solution will be to ease the mast holes in the quaterdeck support and lower gun deck holes together with a cut out on the lower part of the mast.
The fore mast is correct but the main mast will require a very slight adjustment.
Any comments about my solution, a better one etc, will be appreciatd.
I would also like to know where I have gone wrong if possible.
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
willie
#2 Posted : 12 October 2011 14:37:07
increase your hole size in the lower deck make a deck ring, with bottom of the mast remove from one side only till square upper deck beams in crease hole at side till square when all square glue in the lower deck ring to hold in place dont glue the mast yet when fitting the nextdeck and the top poop deck fit around mast checking it, there is three deck rings to go on the top poop deck when finnish [you could only fit two and use the thired as the lower deck ring to save makeing one]also check dowel not bent
and by looking at it the bottom deck could be slighty off centre couple of mm out in the hole can through the mast out a bit the higher you go
Deepseacodmaster
#3 Posted : 12 October 2011 16:42:02
Thanks Willie
I have sorted it now.
It was the bottom hole that was the original problem. I had to remove a fair bit off one side of the bottom of the dowel.
The deck rings are an exccellent method of relocating the mast.( I will be using steel washers or 8mm holes drilled in small pieces of scrap ply.)
I must say I am realy enjoying my build and am very pleased with how it is coming on.
Having this forum has helped me tremendously
BigGrin BigGrin BigGrin
Cheers
#4 Posted : 12 October 2011 16:58:11
Exactly what its here for ThumpUp
willie
#5 Posted : 12 October 2011 17:07:00
the deck rings you dont see, dont need to be round just a square will do as you said with a drilled hole one on the bottom deck would do nice but drill it square or back to the startBigGrin
This page was generated in 0.207 seconds.
