 Rank: Amateur Level 2  Groups: Registered
Joined: 14/04/2013 Posts: 46 Points: 114 Location: Canada
I’ve had this 1/4 scale Yamaha YZR-M1 since before the pandemic & just getting the time, now that I’ve semi-retired to build this model.
Was wondering if any glue was needed for building this model. I’ve watched a few YouTube videos of how it’s put together & for the most part it’s all done with screws, but I may be wrong.
If glue was needed, what brand & type would you recommend? Thanks in advance!
f13dfx wrote:I’ve had this 1/4 scale Yamaha YZR-M1 since before the pandemic & just getting the time, now that I’ve semi-retired to build this model.
Was wondering if any glue was need for building this model. I’ve watched a few YouTube videos of how it’s put together & for the most part it’s all done with screws, but I may be wrong.
If glue was needed, what brand & type would you recommend? Thanks in advance! Hi, To the best of my knowledge, there should not be any need for glue. Where the kit is a bolt together (screw together) its very unlikely. At times you will get press in parts and the odd part may need the smallest spot of super glue should they be a little loose. To date I`ve not needed any glue on lots of builds. Good luck with your build and enjoy your semi-retirement. Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Simply put no, you won’t need glue. I’ve built the Honda and that was just screws. Enjoy the build. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
