Infinity Gauntlet Official Build Issues 17 - 21 Options
#1 Posted : 06 October 2023 19:52:08
Hi All, BigGrin
Well, already here with the next update. This is the start of a new pack, that includes Issues 17 - 21. In this packs building sessions, we will complete the Thumb in issues 17 - 19 and extend the knuckles on the back of the Gauntlet in issues 20 - 21.
All five of the issues in this pack will be small updates, so sit down, buckle up and hold on tight. Flapper LOL
Issue 17 parts are shown in Pic 1.
Retrieve the thumb assembly from the end of issue 16. Then place part A71 (from this issue) onto the base of the thumb and secure it in place using an 02 type screw (silver). Pic 2.
It`s as easy as that, Blink update completed.
Will see you soon for the issue 18 update. BigGrin
(Derek) Admin
#2 Posted : 06 October 2023 21:50:51
Hi Again, Blink
Well I did warn you this was coming soon. Flapper
Another addition to the thumb assembly with the update for Issue 18.
Parts supplied shown in Pic 1 as usual.
We start by positioning the two magnet holders (D03) over the magnets and secure them using four x type 01 screws. Pic 2.
Bring the thumb assembly back from the previous issue and place the parts from the last step in place, securing them with four more type 01 screws. Pic 3.
Part A72 is now placed onto the top of the thumb assembly (between the tip and the central knuckle) and is secured by the use of an 01 type screw. Pic 4.
That concludes this update and your thumb assembly should be the same as in Pic 5.
The next update is for issue 19 and will bring the thumb to a finish, until it is joined to the main part of the Gauntlet and/or the time stone is completed.
Not sure which will come first yet.Confused Confused Watch this space.
Be back soon, take care. BigGrin
(Derek) Admin
#3 Posted : 06 October 2023 22:50:02
Hi all, last one for today, honestly. LOL Flapper
I`ve had a couple of packs delivered due to a previous delay, so I`m playing catch-up and as these updates are relatively small, thought I`d give a few for you to peruse.
So, this is the update for issue 19 and completes the thumb for the time being.
Parts for this issue are shown in Pic 1.
The first part of this update is very easy, so position part D04 inside part A73 and secure them together with an 01 type screw. (black) Pic 2.
Please take note:
The second part to this update needs some care to be taken or damage to parts may occur.
Part A73 can only fit in one orientation, that can be seen by the ridges and lines in the part. By placing the part over the thumb you should see how the parts line up. When happy with the line-up of the parts, part D04 (inside A73) should be directly above the oblong hole in the central thumb joint. Now make sure that the parts stay in line and whilst holding the thumb from the underside, press A73 down onto the thumb. Part D04 should click into place and form the armour plate for the central knuckle joint of the thumb. Pic 3. Another point to note is that the Arrow in Pic 3 is where you need to apply pressure to lock the parts together.
That ends this update, so I`ll see you all soon for issues 20 and 21 and close this pack. Just one thing to note: At this point I weighed the thumb on my kitchen scales and it hit 496 gms. Blink Blink Blink
Hoping to start the next pack construction (Issues 22 - 26) very soon, so keep in touch. ThumpUp ThumpUp ThumpUp
(Derek) Admin
#4 Posted : 07 October 2023 15:49:46
Hi All, BigGrin BigGrin
Two issues to go in this pack and I`m here with the first, which is issue 20.
I will follow on directly with issue 21 as there is not much to do in either issue.
Issue 20 parts are shown in Pic 1.
Recover the assembly for the back of the Gauntlet (Issue 10) and remove the stones if you have kept them in place. This will prevent any damage to them while you work on the inside during this update.
Position part A22 as indicated and fix it in place using 3 x type 01 screws. Pic 2.
Pic 3 shows the stones replaced as this is the end of this update, but if you are going straight on to issue 21, then leave them out until the end of issue 21.
Issue 21 coming soon.Cool Cool
(Derek) Admin
#5 Posted : 07 October 2023 16:13:25
Welcome back, BigGrin BigGrin
This is the last update for this pack, Issue 21.
Its very similar to the last issue with the same amount of work to be done.
Issue 21 parts are shown in Pic 1.
Bring the final assembly back from the last update and if you replaced the stones, remove them again to save causing any damage.
Working on the inside of the previous assembly, fit and secure part A23 with 3 x type 01 screws. Pic 2.
Pic 3 shows the outside of the Gauntlet with the stones replaced and Pic 4 shows how the back of the Gauntlet now looks at the end of this pack.
Work on the next pack is underway and will be posted soon, covering issues 22 - 26.
Until then take care.Cool
(Derek) Admin
