Infinity Gauntlet Official Build Issues 12 - 16 Options
#1 Posted : 28 September 2023 23:07:20
Hi, BigGrin I`m back LOL
Gauntlet update time again, so here we go with the next pack that includes issues 12 - 16.
Issue 12 is all about the second section of the THUMB build.
Parts supplied shown in Pic 1.
Bring parts (C62 and D20) from the parts of this stage to the table. Check out in Pic 2 how these parts should come together and then see the result in Pic 3.
Now bring parts D04 and A68 to the table and position D04 inside A68 as shown in the moulded recess. Pic 4. Then fix part D04 into position using a type 01 screw supplied with this stage. Pic 5.
Position part A68 in line with the end assembly from Issue 11 and then push them together in the direction shown in Pic 6. When the parts click/lock together, they should be the same as that shown in Pic 7.
That ends this update, with the completed assemblies shown in Pic 8.
More updates following soon (all for the thumb), so will be seeing you soon as all the work is done. Blink Blink
Thanks for looking in. Cool
(Derek) Admin
#2 Posted : 29 September 2023 15:40:57
Hi Again, BigGrin
The next update is here and is for Issue 13.Cool
Parts supplied are shown in Pic 1. Note: the screws supplied are of the 02 type (silver).
To start you will need the final assembly from Issue 12 (the thumb tip) and part A67 from Issue 11, on your work table. Position the part A67 just inside the thumb tip as shown in Pic 2. At this point these parts are not fixed together, so exercise care if you have to move them about.
Now position one of the black washers supplied into the side of the thumb tip as indicated in Pic 3. Bring part C62 that has part D20 positioned inside it (from Issue 12) to the table. Push the internal post of part C62 through the hole where you just placed the washer, making sure that the lug fits into the hole as circled in Pic 4. The inside of your assembly should be the same as in Pic 5.
Next part to add is D19. This part fits onto a locating pin and can only fit in one position. Pic 6. Then fix it in place using a type 02 screw. Pic 7.
Continue by putting the second washer in place as shown in Pic 8. Take part C63 and feed the inner post through the washer, making sure that when the part is fully pushed home that the lug fits into the hole as circled in Pic 9. The two side parts are now secured together using another type 02 screw. Pic 10. Note that the part you only rested in place at the beginning of this update is now held in place and can`t fall out.
That ends this update. Part A69 is used in a latter issue. Pic 11.
See you soon for more updates. Please note that Issue 14 is a parts supplied only issue with no work to do, but I will post a pic of the parts to keep things in order.Blink Blink
(Derek) Admin
#3 Posted : 29 September 2023 18:05:39
Hi All, BigGrin
Well here is an update of sorts. Issue 14. Blink
As previously stated this Issue is a parts supply only, without any construction.
Just a Pic of the parts supplied in Pic 1.
So, see you all soon for the update for Issue 15, that is work in progress and will be updated shortly.
(Derek) Admin
#4 Posted : 04 October 2023 16:41:21
Hi All, BigGrin
Back for another session with the update for issue 15.ThumpUp ThumpUp
In issue 15 we build the root of the thumb, that will connect it to the rest of the Gauntlet.
Start by positioning parts C 65 and C67 as shown in Pic 2 and connect the parts together using two type 2 screws (silver) as in Pic 3.
You now need to recover part A70 from Issue 14 and place the two washers (supplied in this issue), on the inside of the pillars of part A70 as in Pic 4. The next step can be a little fiddley, so take care not to damage the washers you just put in place. Position the assembly from the start of this update, in between the pillars of part A70, making sure that the washers stay in situ. Pic 5.
Now, whilst maintaining the position of the parts you just assembled, place part C66 on top so it holds the internal elements in place and locates onto the two pillars of part A70. The alignment of the parts is shown in Pic 6. Finally secure the parts together using two type 1 screws (black) Pic 7.
That brings this update to an end, but I`ll be back soon with the update for Issue 16 that will close this pack. I`m working on the next pack already (Issues 17 - 21) Drool Drool
Take Care All,
(Derek) Admin
#5 Posted : 05 October 2023 17:45:00
Hi Again, BigGrin
With this update we will bring this pack to a close, by bringing the components of the thumb together. This will leave us with just the outer plating to do over the next few issues from the next pack.
So, onto Issue 16. Lots of aligning parts and holding bits together whilst assembling, but if done carefully nothing to worry about.Flapper
To make a start, bring the assembly from the end of issue 15 back to the table, along with part C68. Position the parts as shown in Pic 2 and feed the inner post on the inside of part C68 through the assembly from issue 15. When the part is fully inserted it should match Pic 3. Now bring the part C70 in from the opposite side until C68 and C70 meet together flush. Pic 4. Complete this assembly by fixing it together with an 02 type (silver) screw. Pic 5.
The next task is to bring the two halves of the thumb together.
Place one of the washers (this issue) onto the post of part C64 (issue 14) as shown in Pic 6. Then bring the thumb tip assembly from Issue 12 and pass the post with the washer on (C64) through the thumb tip assembly as indicated by the YELLOW arrow in Pic 7, (but before it is fully inserted),introduce part A69 into the bottom of the thumb (indicated by the RED arrow) Pic 7. NOTE: the pin on A69 will locate into the small hole in C64. If the parts are in the correct orientation then your assembly should be the same as Pic 7 with the Yellow circles indicating the correct positioning.
If you are happy with the positioning of the previous parts, place the second washer onto the other post of part C64 as indicated in Pic 8.
I found this next step was more easily accomplished by laying the two thumb assemblies onto a nice soft towel. Position the lower section of the thumb onto the tip section, where you just placed the washer and swing the lower section inside of the tip. Your assembly should now be the same as that shown in Pic 9. Please pay attention to the three points circled in YELLOW as this is where the next main part will be added.
Before you add the main part to the second side of the thumb, add two more washers as shown in Pic 10.
The last part to add is part C69. This fits into the three places previously indicated, so the two thumb halves may need to be moved slightly to get all three points positioned correctly. When you are happy with the placement fix the whole assembly together using two 02 type screws (silver). Pic 11.
That completes this update, but I thought I`d give you one extra Pic to show just how big this Gauntlet is going to be. Yep that is my thumb for comparison in Pic 12. Told you it was big and it still has metal parts to add.Flapper LOL
See you all soon with the next pack covering Issues 17 -21. Three issues for the thumb first, then two issues to extend the back of the Gauntlet.
(Derek) Admin
This page was generated in 0.261 seconds.
