Excellent work, love the mods you’ve done. The Mars 3 is a great little machine, I bought one when they first came out and recently bought the pro version. The level of detail they produce is shown in the parts you’ve produced. Also love what you’ve done with the paper towel. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Excellent work, love the mods you’ve done. The Mars 3 is a great little machine, I bought one when they first came out and recently bought the pro version. The level of detail they produce is shown in the parts you’ve produced. Also love what you’ve done with the paper towel. Mark Thanks Mark, just wondered of print quality of this little Mars 3. It's very helpfull for these custom project. Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Before to reamde the new fan strap, I moved on to the centerpiece of this whole soup of topics: the turbo. I filled, redid two welds, coat of primer, aluminium, matt black and matt transparent for the turbo chassis - bracket. I covered the shield of the hot side with thermal cloth tape and then with punch&die I "printed" some bolts for the cold side. Before applying the bolts, filled, sanded, metal primer and then a mix of flat aluminium, chrome silver and then Tamiya powders to give the turbo a little more life. Now it seems more turbocharged and less keychain than it was at the beginning         Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
I redesigned the fan strap by resizing the lugs and closing bolt. I already knew that trying to improve the collectors of the kit would be difficult, after two unsatisfactory tests, I redesigned them too I then started assembling all the missing and completely omitted details - right side cams lubrication duct - left side cams lubrication duct - oil pressure sensor - various nuts and bolts of the air conveyor          Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
I continued with job on the top of the engine With the usual water/vinyl way and a single layer of paper I covered the last part of the engine oil conveyor I then worked on the injector rails; Once the injectors were fixed, I added the fitting for the fuel non-return flow on the side. I painted the flutes with stainless grey, matt blue injectors and the fixing base to the monobloc in yellow and the fuel delivery connection in metallic blue        Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Looking very nice, some nice work going into this. Mark Regards Markwarren (Mark) Admin
Very impressive. Regards Markwarren (Mark) Admin
Stunning workmanship and great pics Francesco. Very inspirational. Chris
goddo wrote:Stunning workmanship and great pics Francesco. Very inspirational. Chris Many thanks for you kind words Chris and i continue to do my best with this 911. Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Guest (7)
