Wright Flyer Options
GilShapley
#1 Posted : 19 May 2023 12:49:19
For my next trick-----
Model Airways Wright Flyer. This is 1/16 Scale, That is Wingspan 30" Length 15"
Should be fun. Will post pictures as the build progresses
Gil
BigGrin BigGrin BigGrin
Current Build:-
goddo
#2 Posted : 19 May 2023 14:13:03
Looks an interesting build Gil.
You also have a very impressive list of "Stash and Built" there.
#3 Posted : 22 May 2023 22:44:45
This is a tough build Gil.The finished model is VERY fragile.I am sure you will knock it out of the park.
GilShapley
#4 Posted : 23 May 2023 06:49:34
Not one for the Grandkids to play with then Carl ??
BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
#5 Posted : 24 May 2023 16:26:12
No more like dont breathe when you are near it and dont try to pick it up after you have had coffee with a shot of espresso.
GilShapley
#6 Posted : 24 May 2023 16:51:55
So a glass of beer is a no no
Current Build:-
GilShapley
#7 Posted : 15 August 2023 09:49:09
I put this build on the back burner when I started the UGears Off-Road vehicle.
TBH I was finding the Flyer a rather fussy build. Instructions, how can I put this? Confusing, and need a careful read. The parts are VERY fragile.A lot of glue a bit wait a bit and continue.
Now The Off Roader is done I will return to this build
Fingers crossed
Gil
Current Build:-
GilShapley
#8 Posted : 15 August 2023 13:56:00
This is as far as I got with this build before I started the Off Roader.
Top and Bottom Wings, Their combined weight is 37 grams ?????
The ruler is their to give you an idea of the size of this model
Current Build:-
#9 Posted : 15 August 2023 21:56:02
That kit does look frighteningly fragile Gil, as did the full sized aircraft, but take your time and I'm sure you will produce a stunning model at the end of this build. I'll be watching with great interest! Cool ThumpUp
Kev
#10 Posted : 16 August 2023 00:53:04
Very nice. You must have that in a very safe place to put on the back burner.BigGrin
