Tail wheel Options
cce427
#1 Posted : 31 July 2023 16:33:40
Rank: Amateur Level 1
Some of you may remember me moaning about not getting the last ten or so issues for this model and I was going to set fire to it BigGrin After my third stroke I decided to set to and make all the missing parts, mainly fusalage, tail and wing plates so it is sort of coming together with a lot of filler. I am keen to find a scale tail wheel and cockpit canopy any ideas
cHRIS
#2 Posted : 31 July 2023 18:38:14
cHRIS
Hi Chris, BigGrin
Good to see that you have managed to progress with your Spitfire Build. Cool
Now, as for ideas it my be to your advantage to let us know exactly which issues you are missing. It saves people having to work it out. My guess is that its mostly that last pack somewhere between issues 119 - 125.Blink
Please confirm and you never know, someone out there may just be able to help.
As an after thought, the flat metal plate parts are still in my stash as I`ve not got that far in my own build. I could make you templates of the said parts (at your cost inc p+p) so you can cut out your own parts like the wing plates.
The rear wheel is a different case, but we/I still need to know exactly which parts and from which issue they come from to be able to assist.
This page was generated in 0.146 seconds.
