Very nice updates. Keep 'em coming. Chris
 Rank: Pro Groups: Registered
Joined: 25/02/2017 Posts: 340 Points: 1,019 Location: surrey
Looks like a great build here. Will be watching with great interest. Andy.
Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
Added the base to the second engine.
looks great.Is the engine motorized?
It does have a drive motor, but don't think I will connect it up, since the engines do need attention while they are running and access is not easy once they are installed.
Hi Skyfire, Looking good, but not an easy build, very interesting to see it come together. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
skyfire wrote:It does have a drive motor, but don't think I will connect it up, since the engines do need attention while they are running and access is not easy once they are installed. OK thanks.That makes sense. Carl
Hi Skyfire, Good to see an update on this build, but its such a shame that you have an issue with the running of the engines. As a seriously not cheap kit I would have thought that more attention would have been paid to the running gear. I fully understand you`re method of having the props running and saving the engines and I applaud you for keeping the build going. Looking forward to future updates.  Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
A view of the bow and finally I have the anchors right.
An update on the Titanic.
Hi Skyfire, At that scale it looks fantastic, as you get better detailing.  Keep on with the updates it looks good. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Wow she is a big kit. Looking good so far. Mark Regards Markwarren (Mark) Admin
Added some more decking to the boat deck.
It’s a pleasure looking in on your updates. All coming together nicely. Great work. Andy.
Well, I must say that if it all lights up like that, then the finished model will look great. Keep on with the updates, you`ve got my interest. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Latest bit of work on the Titanic. Added some decking to the forward boat deck. Not going to add the lifeboats just yet, far to easy for things to get damaged.
Changed my mind on the lifeboats and added the davits in. I will add the boats later on.
Added the port side decking and davits.
Guest (5)
