19 Pages «<89101112>»
jonny7england build. Options
budgie
#181 Posted : 09 October 2011 20:00:35
BigGrin looking good Johnny
Confused what size canon balls are you using reason is i want to get some while placing an order over the net
Blushing didn't realise different sizes avail 2mm 2.5mm etc
Ta
#182 Posted : 09 October 2011 20:06:10
Looks great Jonny, keep up the great work mate.
Chris...BigGrin BigGrin BigGrin
jonny7england
#183 Posted : 09 October 2011 20:06:44
Ta
Hi there mate...I'm using 2mm steel cannon balls...BigGrin
jonny7england
#184 Posted : 09 October 2011 20:09:34
Thanks lads...much obliged for your most welcome comments...BigGrin
budgie
#185 Posted : 09 October 2011 20:23:51
BigGrin Thanks for your reply Johnny appreciate it
Cool i will play it safe and order 2mm and 2.5mm as cannons on Surprise might be different than Vic's
Blushing i should have kept one of the Vic's canons instead of giving them away to compare withBigGrin
tom.ganc
#186 Posted : 09 October 2011 23:52:57
Looking good mate. Some nice work here. Still quite alot to catch up but there is no rush here :)
farrabass
#187 Posted : 10 October 2011 12:32:50
Good to see an update from you!
Your build is coming along really well, the cannons take a bit of work but as these aren't fully visible when the next deck goes on, these can be left as they are and the next ones can be finished to a better standard as the tricks and tips learned from the last set will be your starting point for the next set (if that makes any sense).
Keep up the good work.
Steve..
z8000783
#188 Posted : 10 October 2011 12:36:45
Groups: Unapproved
Great looking decks Johnny, well done.
John
#189 Posted : 10 October 2011 12:46:47
Its really looking great Jonny all that hard work paying offBigGrin Cool
Tiswas
#190 Posted : 10 October 2011 18:02:44
Coming along nicely Johny, look forward to seeing more pictures.
TIS
jonny7england
#191 Posted : 10 October 2011 18:50:01
Well, I spent a couple of hours today, gluing the companionway ladders into place then tried to tackle the ropes that surrounded them. I drilled the holes for the ring bolts at the required depth of 3mm...Then, following the instructions in Issue 52, not gluing the ring bolts in, I set about threading and securing the ropes through the ring bolt eyes...The air was turning rapidly blue with my use of the French language which I mastered while planking the hull...Five times the ring bolts fell through the companionway hole, and I had to go searching for the fiendish things!! In the end, I super glued the ring bolts into position first, then fed the rope through the eyes and glued them into place with PVA glue, I used miniature pegs to hold the loops together while the glue dries.
I am now looking at issue 53 and 54 regarding the deck beams and the planking of the same...Hhhmmmm...I'm going to enjoy the next stage!! Catch yer later shipmates...Happy building.
Blink BigGrin
#192 Posted : 10 October 2011 20:25:35
Good stuff JonnyCool
StefanDV
#193 Posted : 10 October 2011 21:29:22
Well done Johnny - you can be proud! (of your build, not the use of the French language LOL)
#194 Posted : 10 October 2011 22:51:01
Keep it up mate looking better each day the more you add to the build..Cool Cool
Chris..
jonny7england
#195 Posted : 11 October 2011 20:34:42
I found that I had several hours to spare today. so I decided to crack on with my build, and the following pictures show my progress. I had finished the companionway then set about cutting strips of 6mm wide lengths to make up the support beams for the deck planking.
That's it for today shipmates, I hope to complete the installation of the deck support beams tomorrow...(after I have ran a taxi service for the missus to and from the shops tomorrow)..Crying Then I can get back to my build, so watch this space...Happy building lads...
P.S...Can't believe that I have taken over 1000 pictures of this build so far!!..Blink
BigGrin ThumpUp
jonny7england
#196 Posted : 13 October 2011 12:03:31
I managed to get a little bit more done this morning and completed the fitting of the support beams for the decking...Blink
Then I set about putting the ship's wheel together..but of course, heavy handed muggins here managed to snap one of the wheel supports...I managed to put the two pieces back together using a dab of super glue...leaving the support t dry on a high...Blink LOL
Once Dry, I shall paint the parts for the ships wheel and glue it all together...But in the meantime, I need to trim the frames as mentioned in issue 54, then crack on with fitting the deck...so watch this space...happy building shipmates...BigGrin
#197 Posted : 13 October 2011 12:19:17
Very nice job JonnyCool BigGrin
tom.ganc
#198 Posted : 13 October 2011 13:37:38
Nice one mate. I can see good progress here :)
Hans
#199 Posted : 13 October 2011 15:07:45
Looking grand, Jonny, looking grandDrool Drool Drool
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
benny
#200 Posted : 13 October 2011 16:38:04
well done looks very nice
cheers benny
