19 Pages «<56789>»
Tom Options
tom.ganc
#121 Posted : 13 September 2011 02:35:13
Hi again
It's been long time since I posted here last time but we are all busy :)
I've received my copper tiles and I'm very excited after reading first part of copper tiling instructions posted today. I hope to get my hands on as quickly as possible.
In the meantime I've created sample part of the hull just to check colours and copper sheating ;)
On the first image you will se hull painted with copper paint and on second tiled with copper.
I'm going to paint it with copper paint before tiling so even if tiling isn't 100% acurate, only thing you will see trough gaps in tiling is copper paint :)
Have a look
1. Copper paint
2. Tiling on top of the copper paint
#122 Posted : 13 September 2011 04:39:00
Good idea Tom
farrabass
#123 Posted : 13 September 2011 12:20:11
Good to see you posting again.
I too am going to tile over a painted hull, I spent a lot of time getting the hull smooth enough to paint, even after all the work that I put in, it would still need further work to make it acceptable. I found the copper paint very difficult to use, but as the paint is going to be tiled on I left it at a stage where the hull is smooth enough to accept tiles.
Have you come to a decision on what adhesive to use, I don't want to start with super glue until I am happy with a system of applying the tiles. There are lots of tutorials around concerning tiling but I will stick with the one on this site.
Good luck Steve..
tom.ganc
#124 Posted : 13 September 2011 12:34:08
Hi mate
I got my hull ready for copper paint. Just need to mark warwe line and mask it.
For the sample I made here I've used aliphatic glue (as for normal woodwork) and it worked quite well. It doesn't set too quick so you have plenty of time to position tile properly. I'm not sure if this will be my choice for model itself though. I need to do some research.
Cheers
tom.ganc
#125 Posted : 09 October 2011 23:50:25
Hiya again
Not been here for ages, sone fantastic builds apeared here.
I managed to get some work done though. Not much, just painting.
I painted lower hull in copper but tiles will go over the pain later on.
As you can see on the second picture the cutout is bit diferent than magazine one but that's my version and I'll stick to it :)
Still need to get some gold painting done on the entry canopies but later on.
One little tip while you painting the model. First I painted whole thing yellow orche, then positioned masking tape. Right now is very important step. Before you paint black just go over with the yellow on the edges where tape meets hull. Not doing it might result in black paint transfer under the tape and tuining your work. Painting it yellow before seals all gaps and then when you peal your tape off after all it looks just perfect.
I hope I made it clear enough BigGrin
Thanks
#126 Posted : 10 October 2011 08:54:59
Shes looking great ThumpUp
jonny7england
#127 Posted : 10 October 2011 09:38:41
What a cracking build Tom...absolutely brill!! ThumpUp
Maldbuild
#128 Posted : 10 October 2011 11:49:45
superb build Tom Drool
#129 Posted : 10 October 2011 12:03:16
Fabulous Job TomCool BigGrin
farrabass
#130 Posted : 10 October 2011 12:26:37
Looking good Tom!!
I have just started tiling, very very difficult and with the copper base coat makes it hard to see if the tiles are butted squarely. Which in one sense does the job the paint is there for, to hide any discrepancies, but if the base coat was a contrast ie. black,white then the butting process would be easier to see when placing the tiles.
But getting back to your build, very impressive, I look forward to seeing your tiling.
Steve..
Tiswas
#131 Posted : 10 October 2011 18:09:26
Great work Tom. Looks really good, well done.
TIS
StefanDV
#132 Posted : 10 October 2011 21:24:35
superb Tom! Your's is a dairy that I always follow as a reference standard.
tom.ganc
#133 Posted : 10 October 2011 22:11:51
Thanks shipmates for kind words. It is still great amount of work to do but I'm really looking forward to it BigGrin
Right now the big job ahead is copper tiling Blink
I need to get upside-down stand prepared and off we go BigGrin
Thanks
#134 Posted : 10 October 2011 22:52:12
Looks great Tom, you should be proud..Cool Cool
Chris..
tom.ganc
#135 Posted : 07 November 2011 14:15:20
Hello
Been busy doing other bits and bats (on Victory of course) bot I'd like to announce that yesterday I started with copper tiles. Quite plesent but slow proces. I've tried few glues but ended up with Evo Stick Serious Glue from B&Q. Works really well, don't set too quick and with special cleaner you can remove all excess quite quickly.
I'll try to get some images soon here. Stay tuned BigGrin
Mr.Quist
#136 Posted : 07 November 2011 17:45:58
Looks superb Tom,
I wish I would be that far.
Cheers, Timm
My build diary here
HMS Victory
#137 Posted : 08 November 2011 00:19:13
Hi Tom,
Great work so clean and precise,that last picture looks so cool thank you for posting you build.
regards tf64.
tom.ganc
#138 Posted : 08 November 2011 01:25:59
Thanks guys. It's nice when somebody likes your work.
Happy modelling.
Hans
#139 Posted : 08 November 2011 08:42:12
HI Tom, Good clean and tidy model. Like your paint work.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
IAN
#140 Posted : 08 November 2011 10:23:28
Hi Tom..
The victory is looking great, very well done.
Best regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
Guest (6)
19 Pages «<56789>»
This page was generated in 0.221 seconds.
