KITT Pack 5 Options
admin
#1 Posted : 21 February 2023 00:18:22
It’s been a challenging couple of months. It started snowing in late December. January it was snowing for real. Average snowfall for a year is 225 inches. We got around 190 inches. Got to the point I couldn’t throw the snow over the banks. The snow banks got up to about 8 or 9 feet. My wife and I have moved a lot of snow.
I got issue 19 last week. It’s been missing in action for a while. The recent build is starting again at issue 19. I have completed thru stage 26. Everything has been going together with no problems. There have been some tight fits, but tight is good.
On to the build!
Issue 19 Turbine and fan wiring
Secure the air intake mount to the turbine front. Make sure the intake mount is tight. Mount the front to the turbine top. The air intake is rather large, the mounting points need to be secure. The three fan wires ( I measured the wires, they were all the correct length) will mount to the side of the electronic control unit on the right side of the front clip. Really can’t see any of this in the booklet photo. I think the photo I took will show the mounting points better. The wire fit to the pins is really too tight. I used a toothpick to open the wire ends so as not to breaks the mounting pins. Issue 19 is complete.
Issue 20 Right side exhaust
No problems, builds exactly as shown.
Issue 21 Left side exhaust
Builds the same as the right side.
Issue 22 Turbine sides and exhaust mounting
Mount the left exhaust to the turbine side as shown.
Mount the right side the same as the left. When I completed these operations, left and right sides of the turbine skewed out and left a very noticeable gap. This gap will disappear when the turbine bottom is mounted in the next issue. Carefully push the pin, 22E into place. The pin is plastic, again, be careful.
This page was generated in 0.244 seconds.
