 Rank: Pro Groups: Registered
Joined: 22/02/2014 Posts: 201 Points: 589 Location: Big T
Good day friends,
This is a trick for mounting tires on wheels. Most suggestions say to use hot or boiling water to soften the tire - I say no, as this will leave water/moisture trapped inside. Or you can hold a noisy hair dryer and wave it back and forth for several minutes.
The best method? A heating pad. Place on high, fold the pad in half and place the tire inside. I just tried it and it works perfectly. No noise, no water. Give it a try.
Yes, the cover could use a wash.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
Sounds good but I do use the almost-boiling water method. I just dry the tyre inside and out before pressing the wheel into it. The heat of the tyre will dry any remaing moisture. Always worked for me - even the terrible (concrete) Mustang tyres.
I use the boiling water trick as well. Usually, after a quick wipe down, the heat evaporates any remaining moisture quickly.
The heating pad method sounds less messy though!
Best,
Plug the pad in, fold it over, tuck the tire/s in, wait a bit and your done. No heating water, soaking and especially wiping excess water off. So simple. Just did the third wheel/tire for the Mercedes-Benz W196R. Works a charm.
Weekend's almost here. Enjoy.
