 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,190 Points: 15,719 Location: ipswich
Stage 2:PART 1. When this stage is complete, store the finished door safely until it is needed. roymattblack attached the following image(s):
Stage 2:PART 2. roymattblack attached the following image(s):
Stage 2:Pack 4 Once completed, you can cut the original Stage 1 packing so that you can safely store the front body section for now. roymattblack attached the following image(s):
STAGE 2:PART 5. As before, once this assembly is completed, store it safely until it is needed in the future. roymattblack attached the following image(s):
Stage 2:PART 5. roymattblack attached the following image(s):
Stage 2:Part 6 When this stage is complete, store the front body panel and the auxiliary lights safely until needed later. roymattblack attached the following image(s):
Stage 2:Part 7 Once complete, store the seat until it is needed later in the build. roymattblack attached the following image(s):
