UK Main Adapter Specification Options
#1 Posted : 17 October 2022 19:32:51
For those wishing to purchase an aftermarket similar adapter, here are the specs. Note: when purchasing take note of the polarity as shown with the positive to the centre terminal with the negative on the outer.
Here is a picture. This is the the UK adapter only.
NathanR
#2 Posted : 18 October 2022 12:31:25
Rank: Beginner Level 3
Thanks for sharing! Do you know the size of the jack? (I can't quite tell if it's 5.5/2.1mm or 5.5/2.5mm)
#3 Posted : 18 October 2022 19:19:35
Hi Nathan
I checked it with a cocktail stick which was 1.95mm and it was too loose. I then checked with a skewer which is 2.79mm. I marked two pen marks on it, the outer was 2.79 and a mark on the tapered end that I measured at 2.5mm. Note the final picture with the pen mark showing is the outer mark at 2.79mm.
It fitted perfectly, so quite confident it is 2.5mm. See pictures.
This page was generated in 0.115 seconds.
