SD 14 Options
budgie
#1 Posted : 08 October 2022 16:32:48
BigGrin Afternoon Folks
Crying As a few of you's are aware I tend to start off well on a new build then dwindle off after I have completed the "skeleton"Crying
Cool Well I have come across a model of the SD14 which consists mainly off a "skeleton" depicting all the frames bulkheads cabins holds etc
I think it would make an interesting object to look at even if I decide not to add the hull plates
The model was designed as a teaching aid for the port fire brigade to familiarise themselves with the layout of the ship so omitting the hull skin should be acceptable
Kit details. http://www.marcle.co.uk/sd14.htm
The real thing. https://www.yfanefa.com/record/24352
If u watched the short video Flapper Think it will take me longer than 16 weeksFlapper
The kit comes printed on 225gsm A3 size manila card
I will be copying those onto card that is glossy on both sides (1:1 as will be nearly 7 feet)
This will save using the originals and ******** it up and also means I do not need to seal the card if painting
Did consider using styrene but would work out quite expensive plus it will be a lot easier to score and fold card rather than score and snap styrene
Hope to get started soon
Thanks for looking'
budgie
#2 Posted : 10 October 2022 19:58:25
Evening Folks
FWD Section
SD14's were normally build on a slipway and when ready to launch the blocks were removed and it would slide into the water after smashing a bottle of champers
The model construction is as a dry dock build
built on a level surface then the dry dock is flooded to float the ship
Bottom Shell Plates
Copied onto 250gsm A3 glossy both sides paper
The 17 templates for the PLATES were cut out and glued using a tacky glue for the K A B C strakes
Will see if I can remember how to upload pics
#3 Posted : 10 October 2022 20:41:34
Yea! Another one to drool over!BigGrin
I love watching you put these together, one day I'll start my Monitor (if only all these extra projects didn't keep getting in the way!)Blink
Looking forward to the next part already.Cool
Best of luck.
Robin.
budgie
#4 Posted : 11 October 2022 20:02:05
BigGrin Thanks for commenting Robin. appreciated
Yeh I do like making a startLOL LOL
Fwd strakes joined together
Looks a bit wavy as it is not flat..joins are overlapped giving hull plating effect when turned over
Hope I don't get bubbles in paper when applying glue even tho it has a gloss surface
Sitting on a A3 platen glass from a photocopier to give idea of size so far
#5 Posted : 11 October 2022 21:21:12
Hi Budgie
It looks like an exciting build not many of us older members post now good to hear from you and good luck with your build.
Trev
budgie
#6 Posted : 02 November 2022 21:32:16
BigGrin Evening Folks
Thanks for comment Trev
I have redone the previous bottom shell plate using 300gsm paper
Reason was that I licked the glossy side to get rid off a mark and the gloss disappeared leaving the rough fibres exposed.Crying
Thought best to change the media before I go further
May have to redo them again tho as not too happy with how the lines line up as couple don't seem to line up quite right
I have cut out the DOUBLE BOTTOM LONGITUDALS that runs fwd to aft and most of the port side DOUBLE BOTTOM FLOORS
Have dry fitted them to see how they look away from the bottom shell plates
budgie
#7 Posted : 04 November 2022 21:11:48
I have glued the longitudals down and dry fitted the "frames"
Couple of frames are missing as I heavy handedly cut thru the fold linesFlapper so will need to redo them
Humming and hawing at the moment on whether to continue this way or restart using a slightly thicker card
The folded parts helps keep the frames steady BUT i quite fancy the idea of seeing as much of the frames and all the other parts as possible ...will I need to do away with the folded part and use a slightly thicker card
Supposed to have been a training aid showing all the compartments etc so covering the hull would defeat the purpose
I am also over thinking the instructions saying to keep flat when it cannot be as the hull plates over lap fwd to aft port to stbd
Still have problems lining up the lines on the hull plates
I just can't seem to get them bang on
Thanks for looking
budgie
#8 Posted : 17 December 2022 12:45:42
BigGrin HI Folks
gone with a thicker card
dry fitted only so far
The t0p of the tank top latitudes will be replaced as i will only use the vertical strips for spacing between the frames
#9 Posted : 17 December 2022 21:27:38
That looks rather special.
Really love how all the symmetry of the parts look.
budgie
#10 Posted : 17 December 2022 22:52:18
BigGrin thanks for taking the time to comment Tony
Failed againCrying tried painting but didn't like the results
Purchased some 0.5mm styrene sheets (not Evergreen)and off I went againLOL
Progress so far
budgie
#11 Posted : 13 March 2023 22:59:59
BigGrin Hi Folks
Progress so far
Starting to glue the longitudes
#12 Posted : 15 March 2023 09:29:45
Hi Budgie,
Good to see you back on this one, keep posting as this is a very special build and very mind absorbing to complete.
Regards Trev.
This page was generated in 0.227 seconds.
