56 Pages «<89101112>»
#181 Posted : 06 October 2011 11:07:55
Good morning Peter,
Thank you! and the answer is yesCool BigGrin
#182 Posted : 06 October 2011 22:13:42
Hi everyone I did say this morning that I would strengthen the frame work made up of parts 17a 16a and 21.
I have finished the task and I am very pleased with it,the frame is very solid now, I made sure that the wood braces I fitted did not interfear with any other part here are some photos:-
#183 Posted : 06 October 2011 22:19:30
Part 21 was fitted with some offcuts of Victory 5mm x 2mm planking.
Part 16a a mixture of planking and some 5mm x 4mm wood I had but you could put 2 pieces of planking together:-
#184 Posted : 06 October 2011 22:23:54
17a was also wood 5mm x 4mm and again it fitted very well, I have included photos of both sides of the frame work:-
#185 Posted : 06 October 2011 22:26:37
And this is the frame fitted, bye for nowBigGrin
S2ksean
#186 Posted : 06 October 2011 23:26:31
This is a great idea mate still think I'm gonna wait till a few more issues come out before I do this (which I will if it isn't strengthened) and I might have copy ya. Sorry mate gotta be done lol.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#187 Posted : 06 October 2011 23:48:32
You must do what you are comfortable with, no problem.BigGrin Cool
willie
#188 Posted : 07 October 2011 11:27:51
no critisum but your keel plate no23 looks off centre in the photos to your center line or is it the way there taken
#189 Posted : 07 October 2011 18:03:59
Hi Willie, Karl mentioned that, its the camera shots, I can assure you so far the build is bang on, but thanks anyway.BigGrin Cool
willie
#190 Posted : 07 October 2011 18:23:27
that's fine, you will know 2mm out at this time farther out down the line
#191 Posted : 10 October 2011 19:55:07
Lokking good mike. Cool
S2ksean
#192 Posted : 10 October 2011 20:00:49
Not long to wait now MWG issue 7 soon lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#193 Posted : 10 October 2011 20:23:15
Thanks Ian, you are right Sean I am really enjoying this buildDrool Cool
#194 Posted : 12 October 2011 23:01:12
ISSUE 7 (12th OCTOBER)
Hi everyone here is my build log for this week, this is what we received:-
#195 Posted : 12 October 2011 23:04:01
Unfortunatly none of the parts were numbered so that was the first job, numbered back and front:-
#196 Posted : 12 October 2011 23:06:06
Then I cut out the pieces as per the instruction, and sanded them:-
#197 Posted : 12 October 2011 23:09:25
This week it is about extending the Bow by adding a further 17cm (6.5 inches)This is where we start.:-
#198 Posted : 12 October 2011 23:12:54
First up we take part 25b and offer it up to the Bow useing parts 25c to reinforce the join:-
#199 Posted : 12 October 2011 23:15:39
Then we fit ribs 26 - 27 - 28:-
Before I did that I used my trusty long bar to sqeeze the joint tight and straight.
#200 Posted : 12 October 2011 23:19:11
Then the other ribs:-
Guest (16)
This page was generated in 0.353 seconds.
