5 Pages <12345>
Malc's Pocher Fiat F2 Options
#41 Posted : 03 August 2022 12:42:29
The drive shaft ends carry Sprockets for the chain drive.( One of the big tasks coming up is to make those chains...BigGrin )
#42 Posted : 14 August 2022 21:03:55
Fabulous modelling as always from you Malc, love the very neat and tidy appearance of your work which helps to give an ultra real look to the finished build?
Very nice indeed! Keep those updates coming, I will be watching. Drool Cool ThumpUp
Kev
#43 Posted : 17 August 2022 13:37:51
Thanks Kev. Always appreciate your kind comments. BigGrin
I'm continuing with the build up of the chassis.
#44 Posted : 21 August 2022 11:14:09
Beautiful work Malc, love that contrast between the black and the brass, very nice! Drool ThumpUp
How are you finding this Pocher kit? I've never built one, though I've heard they are very detailed kits and a bit like a full size engineering project, but not as accurate as they could be in terms of the fit of parts!?
Keep up the good work. ThumpUp
Kev
#45 Posted : 22 August 2022 22:21:25
That's looking like a stunner.
Amazing work here. It's yet another great update.Love
#46 Posted : 23 August 2022 08:00:14
Amazing work Malc, just looks so real.Love Love
#47 Posted : 06 September 2022 11:16:47
Kev
[/size]
Thanks for the comments guys. This is my first Pocher and certainly there's a good level of detail ( considering it's a 1970's kit ). I suspect that some of their other offerings could be much more detailed. The moulding is quite poor generally and brittle...!! I've had quite a bit of repair and additions to make. The fit of parts is hit and miss. Can be frustrating but adds to the challenge I guess.BigGrin
I've got the suspension on now which pretty much completes the chassis.
#48 Posted : 25 October 2022 11:21:27
Progress on this one is a bit slow .... but managed to get a little more done.
I wasn't happy with the brass fuel lines from the fuel tank along both sides of the chassis. The wire diameter looked too large ( 2mm ) so I made my own with 1.5mm brass rod. The fit is better as well.
#49 Posted : 25 October 2022 11:26:53
Engine compartment more or less complete, got the wiring done. It only needs the Carb' to be added. The "cockpit" also completed. I added clear perspex over the dials and some brass fastners to the wood. ( this kit is very basic )BigGrin
#50 Posted : 25 October 2022 12:26:48
It's looking really good. Keep it coming.
It brings back memories of the old wrecked one I had and rebuilt a few years ago.
Great fun.BigGrin
#51 Posted : 29 November 2022 07:58:45
Slow progress but coming together. The final three major tasks are , Making the chain, Upholstering the seats and completing the wheels.BigGrin
#52 Posted : 29 November 2022 08:02:33
#53 Posted : 29 November 2022 16:20:03
Another great update Malc.
It's really coming together now.Love
#54 Posted : 02 December 2022 08:37:06
Hi Malc,
Stunning build a master at work, well done and looking forward to your next post.
Trev
#55 Posted : 03 December 2022 11:08:45
Beautiful work Malc.Love Love
Dinky
#56 Posted : 03 December 2022 14:30:33
Rank: Amateur Level 2
Red Medal: Red Medal
That's a piece of art, its wonderful!
#57 Posted : 23 December 2022 14:32:39
Many thanks to Roy, Mark, Trev and Dinky for the kind comments.
#58 Posted : 23 December 2022 14:33:42
Time to have a go at Upholstery on the two seats. The seats and cushions are from a resin cast and need quite a bit of cleaning up. I sprayed the outer seat section and edged it with Semi-gloss black. The seat cushion is a flat plate with a piece of foam cut and bonded on. The leather is surprisingly stretchy. I used a super glue Gel to attach it.
The final finishing is a series of pins pushed through, bonded at the rear and cut to length.
#59 Posted : 23 December 2022 14:43:13
The “Bucket” for the seat has its piece of cut foam glued in and then the leather is carefully stretched and bonded around the seat edge. Similar pin based buttons added although a hole has to drilled through the much thicker seat section. The pins get bent and bonded before trimming.
#60 Posted : 23 December 2022 14:46:32
Something of a tricky process as described but I'm happy with the overall result. I’ll put a spot of black paint on the pin heads once the second seat is complete. Also some piping to add at the joint between the seat cushions.
5 Pages <12345>
This page was generated in 0.410 seconds.
