Hi!
This is my next major project - a very old B-24 Liberator by Revell - which i had in my stash for decades.DaDokta attached the following image(s): Greetings, Walter
I bought some aftermarket product including a PE-Overkill from Eduard.DaDokta attached the following image(s): Greetings, Walter
As some of you know, i have very little experience with the airbrush and next to no experience with PE - so this will be a challenge, also regarding the old mouldings with raised details!!
So please don`t be too harsh with your comments :)Greetings, Walter
So i gave it a go yesterday.
Scratched away all the original detail of the cockpit and replaced it with PE.
In the Eduard set, there are a lot of prepainted and self-adhesive PE-parts which makes me unsure of when to attach which part regarding the painting.
I only can hope i get everything right.DaDokta attached the following image(s): Greetings, Walter
Hi Walter, This looks like some very nice etch you have acquired for this kit. Also that`s some very small etch, Will be following progress. Good Luck Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work Walter. You’ll be surprised how good it will look once painted. Mark Regards Markwarren (Mark) Admin
Thanks guys!
More removal of original details and replacement with PE.
Almost forgot to fit the little window before attaching the PE!!DaDokta attached the following image(s): Greetings, Walter
Nice work Walter.Looks like with all thoese detail sets this will be a stunner.Good to see Squadron products back.it was a huge online model store in USA that went under a few years back, but a guy and his dad bought the name and are starting to get it uop and running again
Thanks guys,
only little progress has been made preparing bits and pieces, which there are hundreds of.
I`m starting to realize i might have overestimated my skills. Those fiddly PE-parts tend to break very easily.
I have no idea so far how to attach all those inner hull parts, paint them and then put the two halves together without destroying everything.
I´ll be on a vacation for the next three weeks - so enough time to think about it!DaDokta attached the following image(s): Greetings, Walter
Looks like you’re becoming a PE master. Great work. Mark Regards Markwarren (Mark) Admin
Nice work so far Walter, looking very good. I note from your photos that you are bending those PE parts in their raw state, i.e. straight from the brass fret, hence their nice shiny brass colouration and it is probably why they are breaking so easily when you try to bend them? The metal is hard and brittle in its' raw state? You will find PE much easier to work with and bend, if you anneal the whole PE sheet before you start cutting the parts out. This can be done by holding the PE sheet in some pliers or tweezers and then holding it above a cigarette lighter flame until the brass glows red hot and discolours as it cools down? This will anneal the metal and make it much softer, removing the tendency for it to snap when you try to bend it! You will be painting over the parts when they've been added to your model, so the discolouration won't matter?
Hope that helps you Walter and keep those updates coming, I will be watching.
Kev
Thanks for that tip, Kev - i will try that at the next occation.
I´ve been at home forr a few hours between two holiday trips - and after thinking a lot about how all that PE-interior should stay at its place - i came up with the solution of scratch-building some supports.
Also some parts for the waist interior were prepared.DaDokta attached the following image(s): Greetings, Walter
Nice start Walter  you have really a lot of goodies there  should be a great build will be following Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Nice work on the PE parts Walter. You seem to be more skilled at it with every piece you make!
Keep up the good work, will be following.
Kev
Little progress - started with preparation of parts for the bomb bay.
No idea how this should all come together in the end - especially with the the two halves of the hull having to still fit with all the interior stuff.DaDokta attached the following image(s): Greetings, Walter
More great detail going into your build Walter and looking good!
I wouldn't worry too much about whether the two fuselage halves will fit properly with all of this added PE detail. When the PE sets are designed the manufacturers would have the relevant plastic kit to hand and make their measurements accordingly so that it will all fit together in the end?
Keep up the good work Walter, watching with interest.
Kev
I covered up the windows from the inside to prepare for the first spraying action.
Also i openend up some additional windows at the waist.DaDokta attached the following image(s): Greetings, Walter
Nice work again Walter. You are putting a lot of effort into this build and I'm sure that effort will be well rewarded at the end with a stunningly detailed model!?
Keep those updates coming.
Kev
I hope you guys are not bored with me posting every detail of this build. There is so much going on - most of the time just thinking and planning.
All the interior detail is overwhelming - to be able to attach part X you first have to build part Y - but thats not possible before painting part Z - which shouldn`t be painted before attaching part X!!!
Don`t know how to solve all that problems - especially as there are no real reference-builds to find in the internet!
Also i really don`t get along very well with that airbrush - i just can`t get a constant flow.
So it`s all learning by doing but maybe some day in the future someone will benefit from my diary and can avoid some of the problems. Greetings, Walter
As i won`t use the kit part for the waist gunposition i had to build a small box for the "bumper" at the lower waist.DaDokta attached the following image(s): Greetings, Walter
