3 Pages 123>
OcCre London L.C.C. 106 Options
GilShapley
#1 Posted : 10 July 2022 09:50:42
For my next Build I have returned to OcCre as I like their kits.
The London Trolley Bus looks an interesting build, plenty of instructions, lots of bits.
Have started, pictures attached more to follow as I proceed
Current Build:-
#2 Posted : 10 July 2022 10:10:33
It looks like a great kit.
I've been tempted by this one myself, to motorize and run on my garden railway.
I'll be watching with interest.BigGrin
kpnuts
#3 Posted : 10 July 2022 16:28:42
Great start.
#4 Posted : 11 July 2022 01:40:58
ooh I see another Gil masterpiece taking shape nicely.Cant break that OCCRE addiction :) I will be starting my OCCRE titanic shortly
GilShapley
#5 Posted : 11 July 2022 06:38:07
Morning Carl
Nice to see you back on the forum after your recent trials and tribulations with the weather.
After the problems I had with the Fokker build I decided to return to a company I have used before. Good quality parts, plenty of pictures and instructions this old gentleman can follow BigGrin BigGrin BigGrin
Will be adding more pictures as the build progresses
Gil
Current Build:-
goddo
#6 Posted : 11 July 2022 09:05:42
Gil, that looks a lovely kit you have there.
Occre do make some very nice stuff and. after building the model race car recently. it has certainly made me start to think about building other things rather than just HMS Victory.
I look forward to following your build diary.
GilShapley
#7 Posted : 13 July 2022 10:10:03
Progress so far, Lower deck benches installed and varnished, flooring laid and painted. When laying the flooring I laid the first strip down the center of the floor. Each additional strip was then added, with a 1mm gap between each strip until the bench was reached. Made a nice neat even look.
Picture attached
Current Build:-
#8 Posted : 13 July 2022 16:35:55
GilShapley wrote:
Morning Carl
Gil
I just read your Dr1 build diary.You really made a silk purse out of a sows ear with that one.It was a very challenging build when I did mine.I dont know if I ever told you but mine destroyed itself.I had it on a high shelf and it sat up there for about a year with no problems.One day I was across the room for it and I watched it slowly roll forward and nose dive off the shelf and land in a crumpled mess on the floor before I couldt get to it.
#9 Posted : 15 July 2022 15:33:32
Gil
Hope all is good with you.
Could i please ask what sort of markings you have in this kit.
I purchased a number of occre kits a few years ago and at that time the markings were just laser printed onto plain paper. The idea being you cut them out and glue onto the kit.
I did read (i think) recently that the tram kits now come with self adhesive markings?
Thanks
GilShapley
#10 Posted : 15 July 2022 16:12:03
just checked, the markings with this kit are the peel off and apply version. Not got that far yet so will post picture and let you know how good they are when I get there.
ThumpUp ThumpUp ThumpUp ThumpUp ThumpUp
Current Build:-
#11 Posted : 15 July 2022 21:19:28
Many thanks Gil.
Think i will have to contact occre to see if they will replace for me.
GilShapley
#12 Posted : 15 July 2022 21:29:09
I have found them very helpful if their are problems/missing/broken parts with their kits.
They replaced a full set of transfers on one of my train kits no problems at all
Gil
Current Build:-
#13 Posted : 15 July 2022 22:01:36
Gil
Had similar issues with missing parts from their kits so fairly sure they will be able to help.
Hope yours carries on well. Looks like a fun project.
GilShapley
#14 Posted : 04 August 2022 20:57:48
Been a bit of slow progress with this build, Grandkids and decorating has got in the way.
Hopefully now back "on track" pun intended
End panels and sides added to the floor, The inside is varnished. I find it easier to paint/varnish some parts before construction contrary to the build instructions. Each to his own.
Next is to add the supports for the cross beams, once again I have painted these prior to gluing in place.
Pictures attached
Current Build:-
GilShapley
#15 Posted : 18 August 2022 08:34:31
Slow progress on this build for the reasons already stated.
There are 6 frets full of parts, the numbers of which are shown on a plan in the build instructions. This elderly gentleman’s eyes are not what they used to be and in order for me to find the parts required I have scanned the plans, copied them into publisher, doubled the size and printed the result. Now I can see the part numbers
I use the instructions as a guide and do not follow them word for word. I find it easier to paint some of the smaller components prior to assembly. This avoids accidently applying paint where it is not required.
As we all do I have made some small mods as the build proceeds. The “glass” for the windows is a thin plastic. The windows are basically just a hole cut into the ply. In order to make is easier to install the windows I have added frames to the model
The roof supports have eye bolts which I added prior to installing the supports, less chance of any damage to the model if I was to install these after the supports had been fitted to the model as per the instructions
Have started the platforms for each end of the tram, gave me something to do whilst waiting for glue/paint to dry
The cabin roof will be next and here I have a problem. The patterned roof supplied with the kit consists of a printed sheet which is part of the sheet of stick-on labels. This seems rather thin for its purpose and also is sticky backed??. My solution is to stick this “transfer” onto a thin piece of card which will give it some support and allow me to glue it in place on the support beams
Pictures attached
Current Build:-
goddo
#16 Posted : 18 August 2022 11:39:39
Looking good. A nice interesting build which has got my juices flowing.
SWMBO has said that I have to finish one before starting a new model.
Hey Ho!!
GilShapley
#17 Posted : 11 September 2022 11:19:35
Construction has been held up by the grandchildren on school holidays, but now back on it.
End platforms attached, the steps at both ends completed. It is essential to follow the correct order of assembly. This is a curved staircase and if you get the treads in the wrong order it won’t meet the top in the correct place. I assembled a few steps at a time and let the glue set to give a firm base for the next section.
Side covers for the staircases are supplied as pre-shaped metal components which need to be curved to fit the relevant side of the staircase. Transfers are added to the external sides.
The end panels are ply which needs to be soaked and then bent to fit the end platforms. I constructed a simple jig to do this. Worked well. These have yet to be attached.
I have started on the upper deck (filling in time whilst waiting for glue/paint to dry.) Looking forward to the assembly of the 18 chairs !!!!!!
Have also extracted to components to construct the carriage wheels and springs
One thing to note. The kit comes with numbered instructions which are linked to the relevant pictures. I have noticed that it is important to view the pictures carefully and there are occasions when instructions are shown on the picture, but not mentioned in the instructions.
The picture of the upper deck in picture 51 differs from that supplied with the kit. I think the kit must have been updated. Its only minor but threw me for a while. The difference is the small holes around the edge of the deck, these I presume where for the top deck rails. These have been replaced by slots which can be seen in other pictures of the top deck
Pictures attached
Current Build:-
GilShapley
#18 Posted : 11 September 2022 11:25:46
Duplicated some pictures. Should of added this to add this one
Current Build:-
goddo
#19 Posted : 11 September 2022 12:14:26
Hi Gil,
Coming along very nicely indeed.
Lovely attention to detail, especially those curved stairs.
#20 Posted : 11 September 2022 18:35:04
That is coming on very nicely, some great modelling skills.Love Love
3 Pages 123>
This page was generated in 0.257 seconds.
