So this isn't my normal area of building SiFi kits don't really interest me so I only have a couple of model this. But a good friend of mine has asked if I can sort out his Eaglemoss model of the Enterprise D from The Next Generation series. Man this model is MASSIVE  And its really really heavy. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
So this is how I've received it so far its not all here as he's still collecting the series.  So some issues he's had while building the series, one of the lugs will not come out of its location  Massive gap along the rear seam.  Joins not aliening correctly.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Talk about wires   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So first job was to just strip it all down to the main frames and rebuild... While removing sections, I found a wire had been caught under and pinched and believed that was the reason for the gap along the seam.  And after removing all the sections this is where I ended up.  In case my friend is looking in sorry it had to be done And this is what I was left with all bagged up into sections.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So the rebuild starts, I've checked all sections and retightened all the screws.  Found most of them was slightly loose and needed a little turning. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Panels being added.  Managed to sort out the issue with the pins.  Lights working, but there is a lot of light bleeding   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
The simple way to sort to some of the bleeding was with Mr Filler.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Sorted out the wiring.  Panels looking better, but not 100% the fitting of these is horrible so the panels end up where they are no room to move.   Rear seam now looking a lot better.  And these seam look a lot better now, I had to file it a little.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So again with more light bleeding.  Looking better.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Light test for the sections.    More light bleeding, I'm not going to worry about this know I would recommend to my friend to buy some Mr filler 1000 and sit in a dark from with a torch and have some fun  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
And I realised that while I'm building this I can't really do much as it takes so much room up in my workshop... My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Doing a great job from what I`ve seen so far. Been there with the workshop size issue,  the bigger you make it the bigger the stash gets and you enter the vicious circle, but it makes for one hell of a kit collection. Enjoy anyway. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
looks great. I know a few people have really struggled with this kit to get the panels to fit, but you have done a great job with it. Carl
delboy271155 wrote:Doing a great job from what I`ve seen so far. Been there with the workshop size issue,  the bigger you make it the bigger the stash gets and you enter the vicious circle, but it makes for one hell of a kit collection. Enjoy anyway. Regards delboy271155 (Derek) And I have a 3440sq ft shop. I’m in deeeeeeep trouble!
Well no sooner then I started this build it’s finished With the demise of Eaglemoss it looks like my friend won’t be getting any more issues. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Goooood News, the build is back on. I’ll be looking at this again later today My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Mustang wrote:Goooood News, the build is back on. I’ll be looking at this again later today That is really good news. Nice to see this one finished now that the Eaglemoss mess seems to be sorted. Then all you`ll have to do is post it back to your friend, That`s for the future. Keep us posted as to your progress in the meantime. Regards delboy271155 (Derek) Admin COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek thank you for looking in, heres what I've managed to day. More panels added and a second pcb.  And with more panels comes more wires  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Here how she looks form the outside.  I then had a little stumbling block, had the parts for issue 15 but no mag. So after looking for some time and playing with the parts I managed to get most of them fitted, I just need to add some more wires My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Oh and a night time view, just couldn't resist it.   And this is so heavy already and I still have to add the lower dish section. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Guest (5)
