Wheels & Tyres Options
SennaMentalMe
#1 Posted : 05 October 2011 13:31:39
BigGrin Hi all,
Just a thought for everyone:
Although the Japanese McLaren build site is NOT the same as the UK one in terms of order of parts issue, I note that they received their second Rear Wheel/Tyre at issue 44 whereas I would guesstimate that ours will be around 50/51 though I may be wrong ??
With that in mind, I am thinking of ordering double issues from my newsagent on the upcoming Issues 30 & 31, so that I will have the complete set of wheels and tyres for the car in the next three weeks, ready for the completion of the rear suspension and the start of the not too far away chassis parts, rather than wait until much later. I assume they are indentical as the fronts were to each other and I could always sell the later one on as spares nearer the end if needed??
What do you think?? Worth doing?? Good or Bad idea?? It's only money after all!! Blink
Regards ... Kev. BigGrin
scottww86
#2 Posted : 05 October 2011 13:35:39
i could be wrong but are the rear wheels not a slightly different size to the front?? Confused
SennaMentalMe
#3 Posted : 05 October 2011 13:48:42
BigGrin Hi Scott,
Absolutely right, I am aware that the rears are different in size/width to the front. What I meant when I said:
was that they are the same on each side of the axle as in the two fronts are identical to each other and the two rears, although wider, are again identical to each other, but NOT the same as the fronts?? Sounds clear as mud I know, and probably not explained very well by me in the first place, but I hope you get my meaning?? BigGrin ThumpUp
Skiddy
#4 Posted : 05 October 2011 14:36:46
I would like a full set as spares. Then make a tyre trolley and put them in the display case.
If there is a set of wets available as they say then I may use these.
Smeg and the Heads
#5 Posted : 05 October 2011 15:01:15
Hi Kev
The wheels are probably the same on the left and right side but the tyres have direction arrows, therfore you could do what you are suggesting but you'll have to swap one tyre later.
SennaMentalMe
#6 Posted : 05 October 2011 15:56:20
Smeg and the Heads wrote:
Hi Kev
Hi Smeg and the Heads,
I see where you are coming from with your thinking and you are absolutely right!! ThumpUp
Initially I thought that there would be no need to swap a tyre later, having already considered that possibility, as to my thinking, all you would have to do is insert the wheel from a left rotating tyre into the tyre from the opposite side (a horizontal change of 180 degrees) and the left tyre then becomes a right rotating tyre if viewed from the front face of the wheel. In effect the direction arrows from what was originally a left tyre, are now facing backwards NOT forwards, so when fitted to the right hub they will be facing the right way - RIGHT ??? WRONG !!!!!! ... I have missed an important point !!! Blushing Blushing
PROBLEM !!: The tyre beads, where the tyre meets the wheel, have different profile lips on the inner and outer edges, so they could NOT be used in the way I have explained above - DOH - (slaps forehead)!! LOL
Good thinking Smeg and glad you woke me up in time otherwise I could have wasted my money - Thanks mate!!! Blushing Blushing
That solves that one then?? LOL ThumpUp
scottww86
#7 Posted : 05 October 2011 16:18:25
ah!! sorry me being an idiot didnt fully understand! LOL now i know what you mean i think thats a good idea!
SennaMentalMe
#8 Posted : 05 October 2011 16:25:12
BigGrin Hi Scott,
No worries mate, you're not an idiot, I could have worded it slightly clearer in the first place and thanks for the feedback!! BigGrin ThumpUp
SennaMentalMe
#9 Posted : 05 October 2011 16:57:25
BigGrin Hi all,
Re: my post #6 - this is why it's good to talk, that way we save expensive mistakes !!! LOL
Thanks for correcting me though Smeg, Blushing much appreciated and I will be waiting for the last tyre/wheel at the correct time of issue myself now !! ThumpUp
END OF TOPIC !!!!!! LOL LOL
#10 Posted : 05 October 2011 18:56:07
Good post, thats how we all learn KevThumpUp
This page was generated in 0.120 seconds.
