5 Pages «<2345>
Hi, everyone, first time post. Options
Blighty
#61 Posted : 24 April 2022 17:32:38
Rank: Semipro Level 1
Couldn't keep away from the Rocket. Nearly finished the engine and tender, got a couple of wheels to trim, bit of rust to be added here and there. I'll finish off the stack today and place the last pipe coming out of the rh cylinder.
The build was fairly straight forward, nohing to vague. The lugs on the suspension didn't match the slots in the chassis, easily fixed with my trusty file.
The 5mm dia. 'thing' on top of the fire box, I actually drilled a hole in the top of the box and pushed some dowel through for a more secure attachment. This enabled me to use one piece of wire that went straight through a1mm hole I also drilled into the 'thing'. Made that asm easier and I matched the angle both sides on the model.
Only one additional spoke on the wheels snapped when I was shaving off the width on the remaining wheels, just needed more care and sharper chisel to fix that. Attached a couple of pics, hope you like em.
Len
Blighty attached the following image(s):
#62 Posted : 25 April 2022 17:20:37
Hi Len, BigGrin
This is progressing well.Cool Cool
Keep up the good work.
Still following.
#63 Posted : 25 April 2022 18:22:06
It's looking really good.
I'm going to have a go at their Lisbon tram at some point.
kpnuts
#64 Posted : 25 April 2022 19:27:12
Looking good.
GilShapley
#65 Posted : 26 April 2022 14:16:27
Looking good. I do like the aging affect you have achieved, also using something that actually looks like coal and not the gravel OcCre provided.
My next build is going to be the OcCre London Tram. I have the kit already just setting up a workshop in my garage, this will be well out of the way of my grandchildren
Looking forward to your next post
Gil
Current Build:-
#66 Posted : 26 April 2022 15:39:58
Very nice looking model and progressing quickly.
Blighty
#67 Posted : 26 April 2022 20:37:41
delboy271155 wrote:
Hi Len, BigGrin
Still following.
Getting close to final detailing Delboy, I appreciate you following along.
Blighty
#68 Posted : 26 April 2022 20:38:26
Cheers Malc.
Blighty
#69 Posted : 26 April 2022 20:43:05
Gil
I really like those tram kits, I think my next build will be one of that set. I look forward to your build log of the tram.
Thx for following along.
Blighty
#70 Posted : 26 April 2022 20:44:48
I mentioned to Gil I like those tram kits, looking forward to following your log.
Blighty
#71 Posted : 26 April 2022 21:38:20
4 weeks to the day, showing a couple of pics of latest status. All but done the model, a little bit of detailing and a couple of parts to paint. I plan to continue with the log as I'm going to make a case, tracks and a background for it. Not sure if that will be worthy of following, but I don't want this build to finish.
Thx for following along, I look forward to checking out some similar builds as this is the type of kit I like. A big plus to this kit is it is fairly compact, so displaying it on top of the TV or on a shelf is not space prohibitive.
Here's this weeks pics.
kpnuts
#72 Posted : 27 April 2022 06:24:13
Looking very good.
Blighty
#73 Posted : 27 April 2022 23:16:09
Hi,
I've been working on a display case for the Rocket, it's coming along ok. I'm building it on the fly but it's pretty basic so referencing any non existent drgs shouldn't pose a problem. I plan to purchase an acrylic sheet to put round it, that will come later............... The tracks are made from scraps and left overs from other models, I glued up 3 pieces for each track to form an offset I-beam. The actual base which I cut from some scrap planks I had in the garage.
I don't know if anyone can help me? I have been trying to find the correct scale figures, a fire stoker or driver would be ideal. Any idea where I can order one/some?
Blighty
Blighty
#74 Posted : 27 April 2022 23:20:51
Case pics,cforgot to attach.
GilShapley
#75 Posted : 28 April 2022 07:42:06
The scale of the Model is G Gauge or 1:24.
Try a Google search for model railway figures of that scale
Good Luck. ( Ill stick with the Fat Controller on my display. Don't want to upset the Grandkids)
Looking forward to seeing the completed model
Gil
Current Build:-
#76 Posted : 28 April 2022 11:53:48
Looking good, Cool Cool
Here`s a link to some G scale figures:
https://www.dreamsteam.c...6e111ecbe4e303b5b3b76c4
#77 Posted : 29 April 2022 15:11:12
What an excellent job you have done.Love ThumpUp Great work.
Blighty
#78 Posted : 30 April 2022 15:22:43
Thx Mark, been fun upto now.
Blighty
#79 Posted : 30 April 2022 15:32:12
Thx for replies to finding railway figures. Found a couple of good individule figures that are time period accurate(ish), but shipping to Canada adds another $30+ so still looking for something a little less costly.
Here's latest pics of the display case, I just bought some perspex sheet but have not started cutting it up yet.
Blighty
#80 Posted : 01 May 2022 18:29:27
Started cutting it up!
5 Pages «<2345>
This page was generated in 0.201 seconds.
