Replacement charger Options
Flyteach
#1 Posted : 17 April 2022 17:06:50
Rank: Beginner Level 3
Is there a way to order a replacement charger? Or does anyone have the specs for it to see if I can find a replacement?
Thanks!
Flyteach
#2 Posted : 17 April 2022 22:19:01
Thanks!
Flyteach
Hi,
If you go to the last post on the link below you will find the info you need in the attached picture.
https://forum.deagostini....1650230025.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=46278244
Flyteach
#3 Posted : 18 April 2022 18:50:24
Thank you very much Derek. Can anyone confirm if the plug is a 2.5mm or 2.1mm? I know it's center positive. I'm thinking something like this would work: https://www.amazon.com/d...m90TG9nQ2xpY2s9dHJ1ZQ==
Thanks!
Jim/Flyteach
This page was generated in 0.121 seconds.
