Pack 22 and door fit issues? Options
Eagle
#1 Posted : 08 April 2022 00:49:31
Red Medal: Red Medal
Pack 22 arrived today here in the US: The doors do not fit well into the roof section, I highly recommend applying tape to the upper door edge while assembling to protect the paint edges. Anyone else having door fit issues on this stage, and what did you do to improve the fit. I think I may need to elongate the hinge pillar holes to get more door adjustment.
Andreas
#2 Posted : 08 April 2022 08:16:21
Groups: registriert
I finished building the Ford a few weeks ago. Then I dealt with the doors, because I didn't quite like the way the doors were closed either. Here I made my own door seals. The arrows show you where I placed them. You simply take shrink tubing, cut it in half , and stick it in the frame with a little bit off superglue, the problem is solved. No more rattling, best fit and the paintwork on the frames and doors is also protected
Forum Support Team
#3 Posted : 08 April 2022 16:04:48
That's a great tip Andreas.
I haven't reached that point yet but it will be a mod I'll be looking at.BigGrin
GlynD
#4 Posted : 08 April 2022 20:47:43
Rank: Semipro Level 2
Thanks for the heads up guys the finished model really looks superb
admin
#5 Posted : 09 April 2022 05:50:06
This is awesome, Andreas! Simple fix.
Thanks for posting!
semaj
#6 Posted : 21 May 2022 19:41:02
When I came to this stage, one of my doors fitted perfectly but the other wouldn't open/close properly, nothing seemed to line up or anything and it just wouldn't fully shut. It turns out that I have fitted the hinge bracket the wrong way around right at the beginning of the build. Stripped the door down, removed the hinge bracket, turned it around and re assumed everything. Hey presto, the door is a perfect fit.
Building:
Complete:
This page was generated in 0.391 seconds.
