4 Pages «<234
"TALLY-HO" Options
#61 Posted : 31 March 2022 22:25:57
Hi Derek,
Very nice work neat too, It does take a lot of patience to complete the wing and there are some tricky parts to come such as the undercarriage posts and wing housing.
Well done
Trev
#62 Posted : 01 April 2022 11:16:50
tf64 wrote:
Hi Derek,
Well done
Trev
Hi Trev, BigGrin
Thanks for looking in. Cool
Have seen the tricky parts you mention and will be dry fitting a lot to make sure it all comes together correctly. Thanks for the heads up.ThumpUp
#63 Posted : 01 April 2022 15:44:01
Cracking work Derek.Love Love That is some size model.Love
#64 Posted : 01 April 2022 16:40:45
Hi Mark, BigGrin
Thanks for looking in. ThumpUp ThumpUp
Its a kit that needs loads of accuracy when assembling the basic frames so that the panelling fits when you get to that stage, with the least amount of fettling.
Below are some of the stats for the kit to show the size:
1:12 scale
Model Length 760mm. Wingspan 935mm
Functioning items: Variable pitch propeller. Operable Ailerons, Elevator, Rudder, sliding Canopy and opening pilot access door.(If I don`t make any errorsLOL )
#65 Posted : 01 July 2022 20:04:22
Hi All, BigGrin
Gone off line with this a bit as per the instructions order.Blink Blink
Taken a break from the plating, (finger and wrist tendons need a break) and moved onto the wood strips on the fuselage to shape up for the plates on the fuselage.
Haven't pictured it step by step, but have a full pic of each side.
Now have lots of gentle sanding to do, so I can get the best possible shape on the fuselage ready for plating.
Even at this point the jury is still out as to whether this will finish up in Camo or steal finish. That`s still down to how the overall plating etc goes. If there`s lots of gaps and filling is required then it`s Camo finish, no/minimal gaps then it could still be steal finish. My preference is the steal finish, but only time will tell.LOL
Attached are two pics of the fuselage with the added strip wood.
Happy modelling and take care.
#66 Posted : 01 July 2022 21:16:43
Hi Derek,
Thanks for posting your progress to show us all, with all the bits of wood in place and ready for plating, it is so important to sand them flat to look correct.
Don't forget that you will need a Helix Non-skid (rubber back) ruler from W. H. Smiths when you roll down rivets on the metal plates.
Trev
#67 Posted : 02 July 2022 21:14:06
Nice work Derek, steal finish is what I would do as well, just love the look of this model. Love Love
4 Pages «<234
This page was generated in 0.191 seconds.
