GT40 Custom build PACK 3 Options
#1 Posted : 19 March 2022 12:12:38
This pack contains parts 6, 7, 8 & 9.
PART 6:
This set of parts is for assembling the front lights. Assembly is very straightforward, following the kit instructions.
The completed front upper body and lights was then put to one side.
PART 7:
These parts are for the drivers seat.
Assembly is very simple but before the parts were fixed together, all of the gold rivets were painted matt black inside the 'dimples'.
Once dry, the surface of each rivet was wiped over with a cloth dampened with white spirit.
This left the centre of each rivet in black, looking far more authentic.
PART 8:
The part here allows you to complete the build of the drivers seat.
Again, this is very straightforward to assemble.
It can now be seen how much better the seat looks with the black rivet centres.
The side arm rest in the real car has a raised padded section and this was made using a piece of foam board cut to size and then wrapped in thin black leather.
The raised rivets on the kit part were cut off and the arm rest pad glued in place.
PART 9:
The parts provided here form the base of the passenger seat.
They are assembled after first painting the rivet heads as in the previous stage.
The parts can be stored until the seat is completed later on.
This page was generated in 0.182 seconds.
