Body shell rubbing front tyres. Options
Gadget1973
#1 Posted : 14 March 2022 13:52:18
Rank: Newbie
Hi All,
I have an issue that i cant seem to get my head around.
The front tyres rub against the body wheel arches when the steering is used or if the suspension travels.
I have gone back through the instructions several times to see if i had put something together wrong, but it all appears to be correct.
Looking at the pictures on here, the gap between the top of the tyre and the wheel arch seems to be greater than that on mine, but cant see anyway of adjusting the height.
Its a shame as it is a brilliant truck and want to use it, but everytime i turn it makes a horrendous noise.
Any help would be appreciated or has anyone else had this problem? If so what have you done to rectify it?
Thanks
Chris (Newbie)
#2 Posted : 14 March 2022 15:00:47
Hi Chris, BigGrin
Firstly welcome to the forum. Cool
Now I have not built the Hummer, but I`ve noticed looking at the official build that the top of the front shocks are mounted through a specific hole in the carrier. It says to mount them through the middle hole (of three) and I was wondering if you may have inadvertently used the inner holes, as this could alter the ride height.
You can find the official build here:
https://forum.deagostini....1647266341.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=83626197
Hope this helps.
Gadget1973
#3 Posted : 14 March 2022 15:36:16
Rank: Newbie
Thank you Derek for the quick response. I will have a look tonight. Will keep the post updated.
#4 Posted : 14 March 2022 15:43:40
You`re welcome,
This page was generated in 0.171 seconds.
