Help with Issue 79 Options
mredgewe
#1 Posted : 22 February 2022 17:02:56
Rank: Newbie
I have a question for Shelby 500 builders, my part built model has been standing for sometime and the wiring numbers have fallen off and need help with what wire from what component plugs into where on the printed circuit board.
There are letters stamped on the circuit board LC, MT, SC what do they mean.
Thanks Martin
#2 Posted : 22 February 2022 20:25:03
If you can locate each wire (what part it is connected to/comes from) It would be possible to locate the relevant number from the build instructions.
A bit time consuming, but not a problem.
#3 Posted : 24 February 2022 22:51:32
Hi Martin, BigGrin
Finally found my notes on the Mustang wiring that I made in case of anything like this happening at a later stage if something stopped working on my Mustang.
This is the circuit board notation:
1/MT = Accelerator pedal stage 45
2/SC = Brake pedal stage 45
3/LBA = Horn switch stage 63
4/BT3W = Light switch stage 72
5/Battery = Right side panel stage 76
6/SPK = Speaker stage 78
7/W1 = Left headlight stage 87
8/W2 = Right headlight stage 87
9/W3 = Left tail light stage 90
10/W4 = Right tail light stage 90
Hopes this helps with your issue.
This page was generated in 0.229 seconds.
