52 Pages «<4849505152>
#981 Posted : 27 January 2022 21:10:28
Looking from another view.
#982 Posted : 27 January 2022 21:15:33
I then took a full length photo of the port side [left side] of the model, just to show how large it is, measuring 1.4 meters in length [4 feet 7 inches] and it weighs a fair bit too; pushing 5-7 Kg's i reckon!Blink
#983 Posted : 27 January 2022 21:17:09
I then fitted the fore-planes. Again i will 'sit' with the algae effect and see if i need to tone it down or not.
#984 Posted : 27 January 2022 21:17:44
Looking at the fore-planes from above.
#985 Posted : 27 January 2022 21:18:40
Another full length photo, this time showing the starboard side.
#986 Posted : 27 January 2022 21:20:45
I then turned my attention to adding details on the casing. Seen here are cleats and shackle points.
#987 Posted : 27 January 2022 21:21:29
Accommodation space hatch.
#988 Posted : 27 January 2022 21:23:04
This view shows the aft end of the U-boat with the navigation light housing fitted along with two stanchions which will support the radio antennae wires
#989 Posted : 27 January 2022 21:24:42
Looking from another angle.
#990 Posted : 27 January 2022 21:26:07
Singular aft cleat and 4 shackle points fitted.
#991 Posted : 27 January 2022 21:27:44
Rear view showing cleat.
#992 Posted : 27 January 2022 21:28:46
Rear view of aft navigation light and radio antennae stanchions.
#993 Posted : 27 January 2022 21:31:10
That concludes this update, more to follow next week!
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#994 Posted : 28 January 2022 09:24:30
Excellent build, just looks amazing.Love Love
#995 Posted : 03 February 2022 22:18:36
This week i concentrated on making the guard rails that run each side of the casing. I had to do a bit of research on this as the design of these guard rails changed quite a lot throughout WWII. I also referenced photos of U995 and U230 and found them the same, so based my design on that.
I used 0.8mm O/D brass micro tube and brass connecting pieces. Not many photos this week considering the amount if work involved.
#996 Posted : 03 February 2022 22:21:38
The guard rails have not been glued or painted, just fixed together. I still have a bit more 'pushing and pulling' to make sure everything looks right before i apply glue to every joint, then undercoat, weather and fit.
#997 Posted : 03 February 2022 22:24:57
This photo shows the smaller guard rails, located forward of the main sets. These will be connected to the aft guard rails via copper wire; like the real thing, these connecting wires could be removed when the U-boat was alongside and gangways were fitted from the casing to the jetty.
#998 Posted : 03 February 2022 22:26:47
That concludes this update, more content to follow next week.
#999 Posted : 05 February 2022 22:43:19
Excellent work as always Phil, loving all of your weathering on the hull, it really looks as if it's spent many a day beneath the Atlantic hunting the merchant shipping in 'torpedo alley'! Very nice indeed.
As you're nearing the finish line now on this epic build Phil, have you given any thought as to what your next project might be, if any?
Kev
goddo
#1000 Posted : 05 February 2022 23:27:13
Stunning work, Phil.
Fantastic attention to detail and that weathering is superb.
This page was generated in 0.481 seconds.
