Got a screw loose?? Options
SennaMentalMe
#1 Posted : 02 October 2011 15:53:11
BigGrin Hi all,
Like a lot of modellers I love to hear about any useful tips that might be helpful in making my hobby easier or more enjoyable, so I thought that I might share with you, my own system for keeping all those little screws safe in one place until needed and also a way of making them easily accessible with a reduced risk of losing them to the carpet monster!!
I was trying to come up with the best way of storing them but didn't want to spend too much money on a solution and was fiddling with an elastic band at the time when it occurred to me that the answer was already in my hand!! This is how you do it:
Cut an elastic band and open it out. Using a sharp tool make the same number of holes as per the screws for each weekly issue. Then insert the screws in number and type order into the holes along the band. Then using a fine permanent marker pen write the issue number and screw type details on the band after the last screw, then cut off the band at the end. Store in a partitioned box until needed. Hey presto a neat and tidy solution to the problem that can be done quickly every week after the building is finished and the instructions tell you to store the rest of the screws for later in the build !!
The beauty of this system is that the inherent elasticity of the rubber band holds the tiny screws gently but secure without damaging the threads and the screws are easily pushed out when needed. It is also very flexible for storing.
The ID code I use on each band is as follows:
For example: 27:Asx2:Fbx5
Which stands for: Issue 27, type'A'(silver) x 2, type 'F' (black) x 5
A simple and effective filing system for all those little screws and it is a quick and simple matter of finding the correct band for the relevant screws when in a later issue it says to use (for example) the 'type F screws' from issue 27, etc!!
Do you have a screw loose?? Then try my system .... it works!!
Regards ... Kev.BigGrin
SennaMentalMe attached the following image(s):
kryten2b
#2 Posted : 02 October 2011 23:04:14
Useful tip, thanks ThumpUp
Current Builds:
McLaren MP4-23Finished
Millennium Falcon
R2-D2
BTTF Delorean (Maybe)
SennaMentalMe
#3 Posted : 02 October 2011 23:25:27
BigGrin Hi Jerry,
Your welcome mate BigGrin
only1ianuk
#4 Posted : 03 October 2011 00:08:36
I just used one of the little bags supplied throught the issues then taped it closed with masking tape! But i like your thinking Kev!
SennaMentalMe
#5 Posted : 03 October 2011 10:18:32
BigGrin Hi, (is it Ian?)
I too used the little bags and taped them up as you have, but I found it a bit awkward to remove a single screw without struggling, as they are so small and occasionally I would end up with more than one go bouncing across the bench. I wanted something a bit more efficient and hassle free and with this method it is easy to select the correct band and remove just one screw at a time whilst the others stay put!! Plus, you can get a lot of different issues in a small box because the bands aren't as stiff as lots of little bags. Glad you like my thinking though and appreciate your comments.
#6 Posted : 03 October 2011 10:38:08
Nice ideaCool BigGrin
SennaMentalMe
#7 Posted : 03 October 2011 10:43:48
BigGrin Hi Mike,
Glad you like it mate, thanks for the comment. ThumpUp
Regards ... Kev. BigGrin
jameelassan
#8 Posted : 03 October 2011 15:11:20
Message was deleted by User.
bigmal0
#9 Posted : 04 October 2011 22:12:15
Hi, it sounds good but I use a small block of balsa wood about 150x100x20mm, punch some holes slip different size screws into holes, apply a little drop of WD40 and then you can remove screws with tweezers ready for use, simple
SennaMentalMe
#10 Posted : 04 October 2011 22:20:52
BigGrin Hi Mal,
Hi Mal, that is another good way that works perfectly well and I had considered the same, so good thinking, but it still didn't meet my storage requirement very well?? I liked the rubber band system more because I could roll them up and keep lots of issues' screws in a quite small box, whereas the Balsa system is stiff and bulky and not easily written on. Also, I note that you say you have to withdraw the screws with tweezers, which can be a pain sometimes?? With the bands system you can just push the screw gently from one side and extract it with your fingers from the other side, so not really fiddly at all, and also not likely to ping out towards the 'Great Carpet Monster' whereas tweezers can do that sometimes don't you feel??
Both good systems, I agree, each with their own merits and drawbacks, just depends what suits your needs best, I guess?? Great tip though for those who are new to modelling on here, so thanks for sharing it and I appreciate your input. Many thanks mate. BigGrin ThumpUp
andyone
#11 Posted : 05 October 2011 17:47:11
Rank: Amateur level 2
I have a small plastic box with a piece of polystyrene in which I just push screws into in a line and wright next to them easy peasy. Flapper
SennaMentalMe
#12 Posted : 05 October 2011 17:50:18
BigGrin Hi Andy,
Another excellent idea, thanks for posting it up !! ThumpUp
andyone
#13 Posted : 05 October 2011 18:35:04
SennaMentalMe wrote:
BigGrin Hi Andy,
andyone
#14 Posted : 05 October 2011 18:41:30
Has anyone eles noticed that we have 2 screws that are refered to as type "c" one in issue 3 and one in issue 21 and they are diferent threads ?Confused
andyone attached the following image(s):
bigmal0
#15 Posted : 08 October 2011 15:19:46
Hi All, the reason for my balsa method is because I have to do most of my modelling with one hand due to my disability.
Skiddy
#16 Posted : 08 October 2011 20:41:09
Jeez...how the hell do you manage with one hand ? I have trouble with two, and on occasion could do with a third OhMyGod
bigmal0
#17 Posted : 09 October 2011 14:00:23
It just takes a little longer, but Ive been doing this stuff for years and have found ways of adapting. My language choice though has meant I have to be left on my own! Modelling is the one thing that keeps me sane after all what else would I do all day.
This page was generated in 0.187 seconds.
