Good evening from 'The Dockyard'. More progress this week on fitting out the Torpedo Compartment. I started by making the 6 bunk beds and mattresses. 3 of the bunk beds will be folded down. The attached photo shows the component parts made, painted, upholstered and ready for fitting. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Bunk beds fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then built up the 2 torpedoes. I bought these off a supplier in Germany, May 2015. Little did i know at the time that it would be 6.5 years before i got round to making them!  A little clean up needed and they came with separate PE, to make the fins and propellers. I did a fair bit of research on the colour scheme for them, as some pics of the G7 torpedoes showed them painted with red and white nose cones; turns out, these are dummy torpedoes and not the real thing! What i found out was that money was so short in WWII, these torpedoes were mass produced in mild steel, which rusted easily. To prevent this they were slathered in grease, which is why some opinions suggested that they were painted in a green/yellow colour, when in fact they were covered in grease! So i opted for a gun metal colour which has turned out well. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This photo shows the propellers. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows one of the torpedoes supported on mounts, depicting it in storage. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Photo of stored torpedo. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The 2nd torpedo i want to show it being loaded into a torpedo tube to give the compartment a bit of realism and life. First job was to make the loading supports. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Closer look at the loading support detail. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this update, more to follow next week. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
They look brilliant Phil, Mark Regards Markwarren (Mark) Admin
Good afternoon from 'The Dockyard'. Lots of progress made on fitting out the Torpedo Compartment this week. First job was to make the lockers for the crew. Using walnut veneer, i cut out 15 individual locker doors and drilled 2 x 0.8mm diameter holes in each. Crazy, but it wouldn't look the same without! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Lockers fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made a couple of long lengths of pipework using 1.2mm diameter solder. The attached photo shows the pipes cut to length, bent to shape and painted ready for fitting. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows the pipes fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This photo shows the aft end of the pipes. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Next job was to add a little more detail in the shape of two junction boxes. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Junction boxes fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made an isolation valve. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Valve painted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Isolation valve fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
