Banana Rod Options
ajbird74
#1 Posted : 01 October 2011 11:15:04
Hi
Could I please seek some advice as a total novice.
I am building Chatham Yacht in prep for my victory build. I ordered a couple of lengths of 8mm walnut dowel (1 mtr long) from a well known online supplier to replace the ramin mast wood stock.
The wood arrived today along with a 16mm beech dowel.
All 3 lengths are banana shaped, the walnut the worse of the lot.
As this is the first time I have ordered should I expect to see wood arrive in this state?
Thanks for any advice you can offer
IAN
#2 Posted : 01 October 2011 11:32:14
Hi Tony…
This is just a personal view, but I would build the victory as this will give you more confidence and the materials are much better.
I also decided to sidetrack with building the Endeavour and the quality of materials are substandard to me…!
Which makes you feel, you are doing something wrong…!
You might consider carrying on with the Victory build and gain confidence with all the quality builders and there experience, also the master class weekly build with Tomick
Best regards,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
willie
#3 Posted : 01 October 2011 12:40:23
i have had the same why not try decora or b&q some of their dowel rods are rounder and strighter at least you can pick and chouse or for a yacht try the alluminum[CANT SPELL THAT WORD] tube sold there its not that dear
#4 Posted : 02 October 2011 00:13:42
If possible, it's better to choose your own stock via a local model shop or supplier, though the very nature of wood and the machining processes involved, means that on occasion it may not be as true as you might like; and depending on the severety of warp and thickness, trying to straighten it can be almost impossible.
ajbird74
#5 Posted : 02 October 2011 20:52:28
Man thanks to all for your comments and advice.
Appreciated
