 Rank: Pro  Groups: Registered
Joined: 24/01/2011 Posts: 206 Points: 614 Location: halifax
cheers mwg was hard work but i got there
up to issue 49 cal attached the following image(s):
 its a big learning curve m8 but your doing great Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
cheers......... 1st part build ive ever done only ever done plastic kits before this
Np m8 just a quick question as you have concentrated on plastic kits in the past and this is your 1st wooden model, what would your preferances be for future builds. Personaly i find wooden kits more chalenging and rewarding as you actually crafting the entire model from a pile of wood and im not knocking plastic kits either as iv built loads myself over the years Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
i stil like the plastic kits just b4 i started the victory i bought a few plastics kits to do but then the replacments bits came through so i could start on the big girl ill prob go back to the plastic kits unless somthing else come out i like the look of the victory is one ship ive always wanted to build the was the pefect oppertunaty to do it
Good work Cal MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro Groups:
Message was deleted by User.
issue 50 compleated thanks to the fellow builder who pointed out the problem with the galley i think ive sorted it now with some good advice :) cal attached the following image(s):
arpurchase wrote:Np m8 just a quick question as you have concentrated on plastic kits in the past and this is your 1st wooden model, what would your preferances be for future builds. Personaly i find wooden kits more chalenging and rewarding as you actually crafting the entire model from a pile of wood and im not knocking plastic kits either as iv built loads myself over the years Andy Its a good Question and observation. I have only worked in plastic and etch before the victory. I would agree there is more craft involved in the wooden kit i have found it challenging at times and there is some real satisfaction around forming the parts. i will make wood again but i am a bit of a rivet counter so i lice plastic for the accuracy which i am trying to do in building a replica this build will be more of an impression than a scaled down version of the real thing. quite like the look of the more modern ship deag do but also really want to have a stab at the surprise “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Hi Cal lookin like a top build m8 Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
issuue 64 completed after a break from it for a month or so, one or 2 mistakes but only minor ones still enjoying it cal attached the following image(s):
 Rank: Pro Groups:
So long that you are enjoying your build that is all that really matters. For your future reference the cannon trucks have been put together the wrong way around, the widest part should be at the back. No problem with everything else and these cannons will be well obscured with the next deck. Just get the six cannon that appear on the top deck right and everything will be ok. Good luck Steve..
ooops cheers for that ill def double check before building next ones
this version of the lady has sadly & very expensivly been written off (the cat is still hiding from me )keep a look out for the new one (how do i remove this one?)
 Rank: Pro Groups:
Topic locked at Cals request as he's started over here:
http://forum.model-space...aspx?g=posts&t=4598
