10 Pages «<34567>»
Tigerace`s 1/16 Trumpeter King Tiger Options
#81 Posted : 01 November 2021 12:06:50
here is the other part that the cover fits over Cool
#82 Posted : 01 November 2021 12:26:04
Hi lot of correcting work to do ,but your doing a grand job of it keep up the good work cheers mick. BigGrin
#83 Posted : 03 November 2021 20:44:58
Making good progress with this Phil even with the amount of corrections and extra work that you're having to do. It's going to be superbly detailed when finished and I'll be watching all of the way.
Well done, keep it up! Cool ThumpUp
Kev
#84 Posted : 05 November 2021 14:39:15
Thanks Mick ,Kev for your comments BigGrin the super king book i got shows where the kit designer`s guessed or used things from other tanks like the the panther and is a great source of informationCool
Regards PhilCool
#85 Posted : 06 November 2021 12:24:49
So continuing with the cover for the gearbox a strap was fabricated from strip and a brass clasp made for one side and a brass adjuster for the otherBigGrin also new bolt detail was applied on one sideBigGrin
#86 Posted : 06 November 2021 12:28:13
On the final drive housing the flange that attaches to the gear box was reshaped and then glued to the housingBigGrin along with new bolt detail and locking tabsBigGrin Also made the missing lifting rings on the top of the gearboxBigGrin
#87 Posted : 06 November 2021 12:29:35
Then i applied the casting numbers from the Archer decal set BigGrin
#88 Posted : 06 November 2021 12:32:16
Thought i would show the kit part accelerator pedalBlushing
#89 Posted : 06 November 2021 12:33:24
Then next to the new one Blink look how undersized it isBlink
#90 Posted : 06 November 2021 12:35:03
New rear turret hatch arrived Drool Drool this has all the internal detail to it which the kit part lacksBigGrin
#91 Posted : 06 November 2021 12:37:34
The new coaxial mg 34 part arrived from AFV modeler Drool Drool
#92 Posted : 06 November 2021 13:25:34
Excellent work Phil, I can see this is going to be a super-detailed model of the amazing King Tiger! A lot of work for you but boy will it be worth it in the end!? Drool ThumpUp
How did you find those Archer casting numbers? They look to be very sharp in definition. Did they go on easily?
Keep up the good work, will be following all of the way. ThumpUp
Kev
#93 Posted : 06 November 2021 19:24:40
Kev
Yes your right Kev along with the Tiger1 and Panther are my favouritesBigGrin having seen all three in the flesh as well they are huge pieces of engineeringBigGrin and the work continues update to follow .as for the Archer transfers i would say they are simple to use but don`t over work them ,try to get them right the first time as they will come apart, as i found using the resin weld beadsBigGrin
regards PhilCool
P.s i for one am glad your staying on the forum mate BigGrin
#94 Posted : 07 November 2021 12:22:14
This is looking fabulous Phil, top notch work as usual....Drool Drool Drool
#95 Posted : 07 November 2021 13:13:59
Thanks Alan for looking in mate BigGrin
Regards PhilCool
#96 Posted : 07 November 2021 13:15:13
Continuing on the gearbox cover here i`ve added the missing oil filler cap made from lead foil and some rod finished with a nutCool also drilled hole for the dipstick an added to pieces of strip where the name plates areCool and made up the round stamped part of the coverBigGrin
#97 Posted : 07 November 2021 13:22:58
Here i added mr surfacer
#98 Posted : 07 November 2021 13:25:35
I then put the side sponson`s into the hull an added the other suspension reinforcement bars Cool
#99 Posted : 07 November 2021 13:29:16
while these where drying i got the upper hull reinforcement roll bar which sits behind the radio operator and driver BigGrin as this will need modifying as well more ejector marks to fill here Blink
#100 Posted : 07 November 2021 17:36:16
Just catching up on your latest instalments. Great work Phil, taking shape very nicely.Love Love
10 Pages «<34567>»
This page was generated in 0.346 seconds.
