here is the other part that the cover fits over tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Hi lot of correcting work to do ,but your doing a grand job of it keep up the good work cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Making good progress with this Phil even with the amount of corrections and extra work that you're having to do. It's going to be superbly detailed when finished and I'll be watching all of the way.
Well done, keep it up!
Kev
Thanks Mick ,Kev for your comments  the super king book i got shows where the kit designer`s guessed or used things from other tanks like the the panther and is a great source of information Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
So continuing with the cover for the gearbox a strap was fabricated from strip and a brass clasp made for one side and a brass adjuster for the other  also new bolt detail was applied on one side tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
On the final drive housing the flange that attaches to the gear box was reshaped and then glued to the housing  along with new bolt detail and locking tabs  Also made the missing lifting rings on the top of the gearbox tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Then i applied the casting numbers from the Archer decal set tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thought i would show the kit part accelerator pedal tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Then next to the new one  look how undersized it is tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
New rear turret hatch arrived  this has all the internal detail to it which the kit part lacks tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
The new coaxial mg 34 part arrived from AFV modeler tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Kev the Modeller wrote:Excellent work Phil, I can see this is going to be a super-detailed model of the amazing King Tiger! A lot of work for you but boy will it be worth it in the end!?
How did you find those Archer casting numbers? They look to be very sharp in definition. Did they go on easily?
Keep up the good work, will be following all of the way.
Kev
Yes your right Kev along with the Tiger1 and Panther are my favourites  having seen all three in the flesh as well they are huge pieces of engineering  and the work continues update to follow .as for the Archer transfers i would say they are simple to use but don`t over work them ,try to get them right the first time as they will come apart, as i found using the resin weld beads regards Phil P.s i for one am glad your staying on the forum mate COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
This is looking fabulous Phil, top notch work as usual.... Regards Alan
Gandale wrote:This is looking fabulous Phil, top notch work as usual.... Regards Alan Thanks Alan for looking in mate Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Continuing on the gearbox cover here i`ve added the missing oil filler cap made from lead foil and some rod finished with a nut  also drilled hole for the dipstick an added to pieces of strip where the name plates are  and made up the round stamped part of the cover tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Here i added mr surfacer tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
I then put the side sponson`s into the hull an added the other suspension reinforcement bars tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
while these where drying i got the upper hull reinforcement roll bar which sits behind the radio operator and driver  as this will need modifying as well more ejector marks to fill here tigerace attached the following image(s): COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 6,864 Points: 20,909 Location: Northamptonshire, England
Just catching up on your latest instalments. Great work Phil, taking shape very nicely. Mark Regards Markwarren (Mark) Admin
