Sanding sealer Options
IAN
#1 Posted : 29 September 2011 12:16:45
Hi people...
Can you give any Suggestions on how best to use sanding sealer?
Would you use it direct to wood before starting sanding?
Or sand to a good finish then apply the sanding sealer?
would you use the sanding sealer after staining the wood?
Many thanks in advance for any reply,
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
#2 Posted : 29 September 2011 12:43:34
Hi Ian,sanding sealer is a cellulose based grain sealer, normally used to seal the grain of wood,if you read the instruction on the tin,it recommends that you thin it down first with cellulose thinners.I use it a lot this way,after sanding down first with a fine grade sandpaper I then apply the first coat,I then use wet&dry 180 grade for another rub down and apply a second coat.you can continue doing this until you satisfied with the result.if varnishing or painting after this,another rubdown with wet&dry 360 grade and then wipe all residue off with a damp cloth.when staining wood,do so before sandsealing and let dry for 24hours.
IAN
#3 Posted : 29 September 2011 13:09:38
Hi Karl....
It all makes more sence now, to thin down the sanding sealer.
many thanks,
Ian
Ian
#4 Posted : 29 September 2011 20:24:27
Hi Ian
all that Karl has said is good advice for the use of sanding sealer, but did you know u can make your own by adding talcum powder to normal celulose dope, i think its 1 desert spoons of talc to a 500 ml tin of dope, hope this helps as propriety sanding sealers can be quite expensive compared to a tin of dope.Hope this helps
IAN
#5 Posted : 30 September 2011 08:59:55
Hi Andy...
Many thanks for the advice, I just paid £3.99 for the sanding sealer.
Best regards,
Ian
Ian
This page was generated in 0.169 seconds.
