That concludes this update. More to follow next week! Thanks for looking in, have a great weekend and happy modelling!  Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Very nice work Phil, fitting that many tiny valves into such a small space must have driven you absolutely nuts especially when some of them came adrift and had to be done all over again! I love fitting small bits of PE to enhance a model, very therapeutic, but it can be a complete pain in the derriere at times!
Well done Phil, keep it coming!
Kev
Excellent work Phil, give us plenty of warning when you are about to finish as there will be plenty of us having to book into rehab.  Great work. Mark Regards Markwarren (Mark) Admin
Good evening from 'The Dockyard'. Thank you for all the comments! So, it is with great pleasure to announce, <drum roll please>, that THE CONTROL ROOM IS NOW FINISHED! Continuing from last week, i completed the bank of valves and hand wheels. See attached photo. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Overhead shot. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Next step was to finish off painting and highlighting the last crew member to be fitted. He is bent forward, operating a valve hand wheel. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Side view. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
In position. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then turned my attention back to the separate hull section and scratch-built a switchboard and added the part-works supplied motors, which i painted white. I added the junction boxes to each one and then wired them up to the switchboard. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Overhead view. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then fitted and painted a part-works supplied component. No modifications to this part you will be pleased to hear! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Next step was to make up a bank of part-works supplied valves. The original was basically an undefined 'blob' of plastic, which the valve tops and hand wheels would then be fitted too. This 'blob' looked dreadful, so i spent quite some time separating all of the individual valve bodies and reconnecting them with 2.0mm diameter solder. I also added a treadplate walkway. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Similar treatment to the bank of valves seen in the attached photo. This set and the previous set of valves were fitted at the same time as the hull, to get their correct position. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hull section fitted, looking aft. I applied a light dusting of rust to the superstructure, as this represents No3 Main Ballast Starboard and would be full of sea water when the U-boat is dived and empty, as in this case, when surfaced. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hull section, looking forward. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Side view of the aft end of the Control Room. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Side view of the forward end of the Control Room. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Full side view of the finished Control Room! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I see you are still progressing well with this one Phil. It looks top notch. Need to thin out my part works collections (this being one of them) but not sure best route as ebay has some “not ideal” buyers that try it on and you can end up loosing money. Similar with some of the ship kits i have bought in recent years (not going to live long enough to get them all done :-) ) How much more work do you think you have left before you complete your build? Best wishes Tony Happy Modelling
That concludes this update and this stage of the build! Next week i'll move forward on the U-boat to the next compartment which houses the CO's cabin, Officers quarters, Senior Rates quarters, the W/T shack [Wireless & Transmissions] and the Sonar shack. Oh, i forgot, another WC too! Thanks for looking in and your comments, much appreciated! Have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
