52 Pages «<3637383940>»
#741 Posted : 02 September 2021 21:42:35
That concludes this update. More to follow next week!Love
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#742 Posted : 04 September 2021 16:25:34
Very nice work Phil, fitting that many tiny valves into such a small space must have driven you absolutely nuts especially when some of them came adrift and had to be done all over again! I love fitting small bits of PE to enhance a model, very therapeutic, but it can be a complete pain in the derriere at times!
Well done Phil, keep it coming! Drool ThumpUp
Kev
#743 Posted : 04 September 2021 18:32:03
Excellent work Phil, give us plenty of warning when you are about to finish as there will be plenty of us having to book into rehab. LOL Great work.Love Love Love
#744 Posted : 09 September 2021 17:18:56
Thank you for all the comments!
So, it is with great pleasure to announce, <drum roll please>, that THE CONTROL ROOM IS NOW FINISHED!Love Love LOL LOL Flapper Flapper BigGrin
Continuing from last week, i completed the bank of valves and hand wheels. See attached photo.
#745 Posted : 09 September 2021 17:19:48
Overhead shot.
#746 Posted : 09 September 2021 17:21:34
Next step was to finish off painting and highlighting the last crew member to be fitted. He is bent forward, operating a valve hand wheel.
#747 Posted : 09 September 2021 17:23:49
Side view.
#748 Posted : 09 September 2021 17:24:10
In position.
#749 Posted : 09 September 2021 17:26:24
I then turned my attention back to the separate hull section and scratch-built a switchboard and added the part-works supplied motors, which i painted white. I added the junction boxes to each one and then wired them up to the switchboard.
#750 Posted : 09 September 2021 17:26:52
Overhead view.
#751 Posted : 09 September 2021 17:29:10
I then fitted and painted a part-works supplied component. No modifications to this part you will be pleased to hear!Flapper
#752 Posted : 09 September 2021 17:32:58
Next step was to make up a bank of part-works supplied valves. The original was basically an undefined 'blob' of plastic, which the valve tops and hand wheels would then be fitted too. This 'blob' looked dreadful, so i spent quite some time separating all of the individual valve bodies and reconnecting them with 2.0mm diameter solder. I also added a treadplate walkway.
#753 Posted : 09 September 2021 17:36:41
Similar treatment to the bank of valves seen in the attached photo. This set and the previous set of valves were fitted at the same time as the hull, to get their correct position.
#754 Posted : 09 September 2021 17:39:17
Hull section fitted, looking aft. I applied a light dusting of rust to the superstructure, as this represents No3 Main Ballast Starboard and would be full of sea water when the U-boat is dived and empty, as in this case, when surfaced.
#755 Posted : 09 September 2021 17:40:06
Hull section, looking forward.
#756 Posted : 09 September 2021 17:43:53
Side view of the aft end of the Control Room.
#757 Posted : 09 September 2021 17:44:59
Side view of the forward end of the Control Room.
#758 Posted : 09 September 2021 17:46:35
Full side view of the finished Control Room!BigGrin
#759 Posted : 09 September 2021 17:48:27
I see you are still progressing well with this one Phil. It looks top notch.
Need to thin out my part works collections (this being one of them) but not sure best route as ebay has some “not ideal” buyers that try it on and you can end up loosing money.
Similar with some of the ship kits i have bought in recent years (not going to live long enough to get them all done :-) )
How much more work do you think you have left before you complete your build?
Best wishes
#760 Posted : 09 September 2021 17:51:55
That concludes this update and this stage of the build! Next week i'll move forward on the U-boat to the next compartment which houses the CO's cabin, Officers quarters, Senior Rates quarters, the W/T shack [Wireless & Transmissions] and the Sonar shack. Oh, i forgot, another WC too!LOL
Thanks for looking in and your comments, much appreciated! Have a great weekend and happy modelling!BigGrin
This page was generated in 0.621 seconds.
