Joined: 06/09/2011 Posts: 115 Points: 354 Location: Bristol
Hi All Hanger Deck plating scribed into plastic and glued to hull. Areas masked off for structure. Ken attached the following image(s): Ken
Completed Models IJN Yamato, Hachette Titanic, Del Prado Victory, Tamiya 1/16 RC Pershing Tank, HMS Naiad, HMS Prince of Wales, Admiral Hipper, Tirpitz, USS North Carolina [Current Build USS Enterprise CV6
Very nice work Ken. Mark Regards Markwarren (Mark) Admin
Hi All, Thanks Mark for the comment. Fitted some of the hanger deck structure so that the sides of the hull could be completed. Time to get the masking tape out and start spraying the hull. Ken attached the following image(s): Ken
Hi All, Hull completed and painted. Prop shafts made up ready for painting before fixing. Masking tape has been left on the decks as detail has to be added to already positioned structures before final paint. Noticed on pictures some bleed through of paint under masking tape. Something to touch up later. Ken attached the following image(s): Ken
 Hi Ken your not messing about building her.... all that done already Looking' good
Very nice work Ken and a great conversion. I think this will be something special when completed?!
Very well done on your progress so far.
KevPer Ardua Ad Astra
Hi Guys, Thanks for the comments. The build does seem to be going quick, but being retired I now have a lot of time to spend building models. Progress will slow down when the detailing work is being done. Will keep posting. Ken
Hi All, Started work on the detailing. Made up the bow elevator walls when I was waiting for materials to complete the hull. Ken attached the following image(s): Ken
Some build this Ken  great so far Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Just catching up with your progress Ken. Looking excellent. Mark Regards Markwarren (Mark) Admin
Hi Guys, Progress has mainly been in the bow area. This is the first stage as more parts will be added later to support the flight deck. A set of laser cut card parts are available as part of the card Kit and these are being used as the detail is very good and also difficult to cut out accurately. All laser cut pieces are sealed with thin superglue prior to painting. Ken attached the following image(s): Ken
Hi Ken, This is an astounding conversion from a cardboard kit and I commend your work. Looking really good. WTG. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Coming together beautifully Ken, looking fab.... Regards Alan
Hi Guys, Build progressing. Been busy with stern elevator and stern deck. Ken attached the following image(s): Ken
Hi All, Thanks for the comments. Work has progressed to the hanger deck structure. Using the laser cut card as supplied with kit stuck using a card glue. Work to starboard side is going to be completed first before the inside details. Used the card spacers where needed and stuck to the plastic card using a RC modellers glue that I have had for ages (now discontinued), but looking for an alternative. Completed parts are dry fitted at the moment. Ken attached the following image(s): Ken
Hi All, Work progressing with starboard side. Ken attached the following image(s): Ken
You are doing great work on this Ken  look forward to your next update Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Hi All Comments are appreciated and will keep on posting. Starboard side progressing well. Have added internal detail and have left all roller shutter doors in an open position so that it can be seen when flight deck is fitted. Ken attached the following image(s): Ken
 Hi Ken Enjoying your progress…she’s lookin good I take it that the “raised” details like pipe work etc are copied from the the “flat” detail printed on the card using appropriate sizes of styrene etc Will look fwd to next update
Hi Budgie, Thank you for your comment. You are correct in your guess. I am using styrene rod, copper wire to bring out the details that are lines on the flat card by best guess. Ken Ken
