Just amazing Phil. This build diary is always one of my most eagerly anticipated when it comes to seeing the latest updates on your model. You'd better hurry up and get it finished though, as I'm fast running out of superlatives to use in my comments without repeating myself!
Top job as always - keep it coming!
KevPer Ardua Ad Astra
Just excellent Phil, I too am running out at what to say. Mark Regards Markwarren (Mark) Admin
Good evening from 'The Dockyard'. More progress on fitting out the Control Room of my 1/48 scale build of Type VIIC U-boat U230. This week, or rather last weekend, was detail, detail and more detail. I concentrated on the housing for the attack periscope. I painted the 3 sections that make up the cylindrical shape and supplied with the part-works, then went to town adding pipes and valves. The attached photo how much detail i added, using 0.3mm, 0.7mm and 1.2mm diameter solder for the pipework and small, brass strips for valve handles. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Rotated round for another angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Rotated further. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Final rotation showing the last quarter. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Cylinders painted and fitted; part-works supplied. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Attack periscope housing fitted along with the deck plate. This was all a very tight fit, even after liberal filing here and there and lots of fitting, removing and refitting. In the process i managed to knock off a couple of the small details on the periscope housing, which isn't surprising considering the tight space, but glued them back on after. Phew! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From another angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then decided to fit the lighting to the Control Room before i add the last details and the crew. When fitting the lighting in previous posts, it's always a bit hairy when i have to invert the model. Fortunately nothing fell off, including the crew, but this time i thought i would mitigate that little bit of stress and fit it now. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Red lighting fitted and working! For those that don't know and wonder why submarines have red lighting in the Control Room, i'll explain. When the OOW [Office Of the Watch] is looking through either periscope, the lighting inside the submarine must be slightly darker than what he can see through the eyepiece, other wise he can't see anything right? If you look out of your kitchen window for example, at night and your light is on, you can't see outside but only your reflection. Turn your light off and viola, you can see outside far better. Same principle with submarines. During the day, the Control Room will have normal white lighting on, no problem. Then when dusk arrives, or dawn, this lighting is switched to red lighting. During the night, red lighting is switched off completely and only the dials on the gauges are illuminated. Your eyes soon become accustomed and within 20mins you can still see everything. I have fitted red lighting as i imagine my model of U230 is leaving port to go on patrol at dusk. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Another shot. I imagined dusk for the setting of my model, but in reality i took these photos at dawn with the kitchen light off at about 06:00! Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From another angle and i have to say, i'm very chuffed with the results. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Lighting off, i then fitted the ballast pump which i previewed in last weeks post. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this post, another update to follow next week. Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That control room looks nothing short of outstanding. A wonderful display of craftsmanship....  .. Very well done.... Regards Alan
Another amazing log on the U-Boat build. The level of detail is mind boggling. Chris
Another superb update phil Regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
I`m stunned beyond words, so................... Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
I’m getting stuck for words to say, stunning work. Mark Regards Markwarren (Mark) Admin
Guest (6)
