52 Pages «<3334353637>»
#681 Posted : 07 August 2021 17:26:25
Just amazing Phil. This build diary is always one of my most eagerly anticipated when it comes to seeing the latest updates on your model. You'd better hurry up and get it finished though, as I'm fast running out of superlatives to use in my comments without repeating myself!
Top job as always - keep it coming! Drool ThumpUp
Kev
#682 Posted : 08 August 2021 08:36:51
Just excellent Phil, I too am running out at what to say.Love Love Drool
#683 Posted : 12 August 2021 20:29:03
More progress on fitting out the Control Room of my 1/48 scale build of Type VIIC U-boat U230.
This week, or rather last weekend, was detail, detail and more detail. I concentrated on the housing for the attack periscope. I painted the 3 sections that make up the cylindrical shape and supplied with the part-works, then went to town adding pipes and valves.
The attached photo how much detail i added, using 0.3mm, 0.7mm and 1.2mm diameter solder for the pipework and small, brass strips for valve handles.
#684 Posted : 12 August 2021 20:30:16
Rotated round for another angle.
#685 Posted : 12 August 2021 20:30:40
Rotated further.
#686 Posted : 12 August 2021 20:31:17
Final rotation showing the last quarter.
#687 Posted : 12 August 2021 20:32:23
Cylinders painted and fitted; part-works supplied.
#688 Posted : 12 August 2021 20:35:14
Attack periscope housing fitted along with the deck plate. This was all a very tight fit, even after liberal filing here and there and lots of fitting, removing and refitting. In the process i managed to knock off a couple of the small details on the periscope housing, which isn't surprising considering the tight space, but glued them back on after. Phew!Blink
#689 Posted : 12 August 2021 20:35:42
From another angle.
#690 Posted : 12 August 2021 20:41:06
I then decided to fit the lighting to the Control Room before i add the last details and the crew. When fitting the lighting in previous posts, it's always a bit hairy when i have to invert the model. Fortunately nothing fell off, including the crew, but this time i thought i would mitigate that little bit of stress and fit it now. LOL
#691 Posted : 12 August 2021 20:51:16
Red lighting fitted and working!BigGrin
For those that don't know and wonder why submarines have red lighting in the Control Room, i'll explain.
When the OOW [Office Of the Watch] is looking through either periscope, the lighting inside the submarine must be slightly darker than what he can see through the eyepiece, other wise he can't see anything right? If you look out of your kitchen window for example, at night and your light is on, you can't see outside but only your reflection. Turn your light off and viola, you can see outside far better. Same principle with submarines.
During the day, the Control Room will have normal white lighting on, no problem. Then when dusk arrives, or dawn, this lighting is switched to red lighting. During the night, red lighting is switched off completely and only the dials on the gauges are illuminated. Your eyes soon become accustomed and within 20mins you can still see everything.
I have fitted red lighting as i imagine my model of U230 is leaving port to go on patrol at dusk.
#692 Posted : 12 August 2021 20:53:26
Another shot. I imagined dusk for the setting of my model, but in reality i took these photos at dawn with the kitchen light off at about 06:00!LOL
#693 Posted : 12 August 2021 20:54:50
From another angle and i have to say, i'm very chuffed with the results.BigGrin
#694 Posted : 12 August 2021 20:55:43
Lighting off, i then fitted the ballast pump which i previewed in last weeks post.
#695 Posted : 12 August 2021 20:56:50
That concludes this post, another update to follow next week.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#696 Posted : 13 August 2021 12:05:14
That control room looks nothing short of outstanding. A wonderful display of craftsmanship....Love Love Love .. Very well done....
goddo
#697 Posted : 13 August 2021 14:00:04
Another amazing log on the U-Boat build.
The level of detail is mind boggling.
#698 Posted : 15 August 2021 12:01:32
Another superb update philDrool Drool Drool
Regards PhilCool
#699 Posted : 17 August 2021 17:20:14
I`m stunned beyond words, so...................
Cool Cool Cool Cool Cool
#700 Posted : 18 August 2021 08:25:07
I’m getting stuck for words to say, stunning work.Love Love
This page was generated in 0.374 seconds.
