13 Pages «<910111213>
Micks 1/200 battleship bismarck Options
#201 Posted : 05 July 2021 12:20:03
Issue 113
Here we assemble the elevation gear box, I put the motor on while off the model as working underneath is so fiddly, after testing it works first. Then it's just fix this underneath the gun turret. Cheers mick BigGrin
#202 Posted : 05 July 2021 12:27:59
Issue 114
First of all we attach another hull plate, then fit the bilge keels to the hull these are just a press fit, then make up the 8 vents with there etch grills and glue these in place around the 3rd main gun barbette. That's me caught up with this for now. Next parts are all hull plates so we finally get a full hull. Cheers mick. BigGrin
#203 Posted : 05 July 2021 23:10:43
Lovely progress Mick, good to see her move on.... Look forward to seeing your next update....Drool Drool Drool
#204 Posted : 08 August 2021 10:55:50
Issue 115
Here just another couple of Hull plates to fix cheers mick. BigGrin
#205 Posted : 08 August 2021 10:59:12
Issue 116
Here again just couple hull plates to fix after painting in the portholes cheers mick. BigGrin
#206 Posted : 08 August 2021 11:02:21
Issue 117
Here we fix the turret rotation motor under the third main turret. Cheers mick. BigGrin
#207 Posted : 08 August 2021 11:06:24
Issue 118
Here we fit the stern to the ship finally completing the hull yay no more hull plates. Cheers mick. BigGrin
#208 Posted : 08 August 2021 17:06:04
Excellent work all round Mick and glad for you that you have finally completed building the hull. Always a nice warm satisfied feeling for the modeller when a significant stage of any model build is completed!?
Well done Mick, keep it up. Cool ThumpUp
Kev
#209 Posted : 25 October 2021 11:25:02
Hi thanks to all who looked in and left comments much appreciated
Issue 119
We just get the aft circuit board here, but there is nothing to do in this issue Cheers mick BigGrin
#210 Posted : 25 October 2021 11:30:50
Issue 120
Here we get the 2 outer propellers but there not fitted till next issue we just install the aft circuit board from the last issue and do electrics test on the aft superstructure, mine all worked as should. Cheers mick BigGrin
#211 Posted : 25 October 2021 11:37:03
Issue 121
Here we get the central propeller then fit all 3 propellers to the ship. Cheers mick BigGrin
#212 Posted : 25 October 2021 11:42:34
Issue 122
Here we get the gearbox for the propellers and fit it. Cheers mick BigGrin
#213 Posted : 25 October 2021 11:48:37
Issue 123
Here we get the twin rudders and motor for them just fit these in the hull the motor is loose fitting at the moment but is fixed in later issue. Cheers mick BigGrin
#214 Posted : 25 October 2021 11:52:40
Issue 124
Here we get the aft anchor motor and gearbox to fit in the ship. Cheers mick BigGrin
#215 Posted : 25 October 2021 12:06:15
Issue 125
Here we get the main mast and four aa guns first of all assemble the main mast as per instructions and fit in place on the aft superstructure, then assemble the four aa guns and put in place then there couple long vent pipes to add each side of the main mast and finally some etch walkways to fit to the bottom of the boat cradles. BigGrin
#216 Posted : 25 October 2021 12:15:28
Issue 126
Here we get the eighth bit of main deck plus details to add and more handrail for the aft superstructure. Cheers mick. BigGrin
#217 Posted : 26 October 2021 09:18:50
Looking great Mick. That is some size now.Love Love
#218 Posted : 27 October 2021 14:30:51
Excellent work on your Bismarck Mick, an amazing amount of detail in this build and as Mark says, it's certainly becoming an impressively large model!
Well done. Cool ThumpUp
Kev
#219 Posted : 31 October 2021 16:24:31
Hi thanks Mark and Kev for comments left much appreciated
Issue 127
Here we get the last bit of deck after painting it and adding the swastika decal it's just glue load of hatches join it to previous bit of deck add the etch platforms around third main gun and 4 pe ladders to put on aft superstructure cheers mick. BigGrin
#220 Posted : 31 October 2021 16:28:39
Issue 128
Here we get the final main turret assembled the same as previous 3,so only took pic of finished gun. Cheers mick. BigGrin
This page was generated in 0.428 seconds.
