52 Pages «<3031323334>»
#621 Posted : 17 June 2021 17:46:48
This crew member has no cards as they're laid out on the table. In my mind they are all playing 'Pontoon'.
#622 Posted : 17 June 2021 17:47:34
Final crew member of the 'card school', card in hand.
#623 Posted : 17 June 2021 17:48:44
All crew members fitted on the pulled down bunks. More pillows and rolled up sleeping bags added. The Junior Rates Accommodation space is now complete!!
#624 Posted : 17 June 2021 17:51:24
Well that's this section completed. Next week i start on a new phase of this build!
Thanks for looking in, have a great weekend and happy modelling!BigGrin
goddo
#625 Posted : 17 June 2021 19:26:54
This is an amazing level of detail, Phil.
All you need now are some glasses and a bottle of whiskey, a pencil and score sheet for the cards.
Apologies, no alcohol when on duty.
Or how about a crib board?
OK, I'm being silly now.
Still a brilliant build diary, well done.
#626 Posted : 18 June 2021 07:12:00
Hi Phil,
Well done with the crew members look the part.
Trev
#627 Posted : 24 June 2021 07:12:05
So this week i made a start on fitting lighting to the completed compartments. Initially i was in two minds whether too or not, but after fitting out the Galley, i noticed how dark it was, so that was the impetus i needed.
I bought a lighting kit, designed for 1/48 scale u-boats, quite a while ago. All the resistors were pre-fitted to each nano LED, of which there are 15 in the kit along with one green and one red.
I also purchased some marine style 3d printed light fittings with lens covers.
The attached photo shows the base of the one of the light fittings, painted white and a nano LED held in place with double-sided tape. The light was tested beforehand to check it worked.
#628 Posted : 24 June 2021 07:16:10
The wires entering the light fitting were given a small blob of glue as extra fixing and the lens cover fitted, again, with glue, not superglue or PVA , but a crafting glue that can be easily separated if needed.
#629 Posted : 24 June 2021 07:22:09
The wiring for all of the lighting will be routed down into the battery compartment below the Junior Rates Accommodation space.
Some of the nano LED's had to have extra lengths of wire spliced onto them to make up their length and heat shrink added.
The attached photo shows the wiring for 4 lights routed, ready for connection. The 4 lights are for the Aft Torpedo compartment, Engine Room, Galley and Junior Rates Accommodation space.
#630 Posted : 24 June 2021 07:31:28
The attached photo shows the wires for the 4 lights routed to a chock block. The chock block will eventually be covered over with a plastic box shape and made to look like locker storage, but not until all of the lighting is completed.
Lighting for the rest of the u-boat will be routed in the same way to another chock block next to this one, whereby both their feeds are routed down to the Battery Compartment below. Bullet connectors will be fitted to the ends of these feeds so that the switch and batteries that power the nano LED's can be easily disconnected. The wires and connectors in the Battery Compartment will eventually
be hidden by scratch-built u-boat batteries.
#631 Posted : 24 June 2021 07:34:06
Aft Torpedo Compartment lighting!BigGrin
#632 Posted : 24 June 2021 07:35:17
Engine Room lighting!BigGrin
#633 Posted : 24 June 2021 07:36:13
Galley and Junior Rates Accommodation space lighting!BigGrin
#634 Posted : 24 June 2021 07:40:35
The rest of the lighting will be added as each of the remaining compartments get fitted out. Only then will i finish off the overall look and hide away the chock blocks etc.
That concludes this update, next week i move onto the main focus of the u-boat; the Control Room.
#635 Posted : 24 June 2021 12:20:58
Phil it`s a joy to watch you build this mate outstanding as always Drool Drool Drool
Regards PhilCool
#636 Posted : 25 June 2021 18:31:25
Stunning work Phil as usual.Love Love Drool
#637 Posted : 01 July 2021 07:34:45
So this week i started on fitting out the Control Room, the nerve centre of all submarines.
I began by soldering together the part works supplied etched brass that makes up the hull infra-structure.
#638 Posted : 01 July 2021 07:36:54
The infra-structure looking from another angle. At this point i put it to one side and will come back to it during the final stages of fitting out the Control Room. I enjoy the soldering side of things and intend to more on future model making projects.
#639 Posted : 01 July 2021 07:38:30
I then turned my attention to the bulkheads, fore and aft. In the attached photo, they have both been painted in white and sky grey with a matt black lower edge painted around the bulkhead door opening.
#640 Posted : 01 July 2021 07:43:36
The aft bulkhead completed. 50% of this was part-works supplied, which looked very basic and did the bulkhead no justice at all, so the other 50% that you can see i scratch-built; junction boxes, pipes, valve handwheels, an ammeter gauge, all pin-washed to bring out their detail.
This page was generated in 0.467 seconds.
