10 Pages <1234>»
Sean's HMS hood Options
willie
#21 Posted : 16 September 2011 22:02:28
S2ksean wrote:
Cheers tis and mwg be nice when the hull skeleton is done. By the Way does anyone no when that will be?
take a look at the buil log the weekly of the bismarck on the net its from the same company if it follows the same rout it will give you an idear when the skeleton is done
S2ksean
#22 Posted : 16 September 2011 22:04:34
Cheers willie il find it and have butchers lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#23 Posted : 16 September 2011 22:09:58
type in build the bismach its the second one down
Zeptrader
#24 Posted : 17 September 2011 08:32:12
at about week 11 the bismarck had the planks going on.
http://www.buildthebismarck.co.uk/011.htm
then at a guess about issue 16/17 the decking? only a guess mind;)
S2ksean
#25 Posted : 20 September 2011 21:27:10
Cheers zep I'm looking forward ta part 4 now out 2moro
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#26 Posted : 21 September 2011 18:08:33
Is there anyone else having problems getting issues from there newsagents
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
alantait
#27 Posted : 21 September 2011 18:13:18
yeh, my local wh smith has issue 1 and 2 only (about 10 off each on the shelf), the guy said he had not seen any more so i dont think this is a hit here.
Confused
current builds
willie
#28 Posted : 21 September 2011 19:13:00
Confused
with hw smith you have to place an order with a down payement of £15 they seem to only hold first two parts try asda they have them
S2ksean
#29 Posted : 22 September 2011 20:19:40
Finally got my hands on the next installment and here it is
Issue 4
That's it for this one. the hull is getting there im still bit nervous about the planking side ov things but It will be few weeks yet before I have ta properly start worrying about that. As I said in previous posts this is my first wooden one so all comments welcome. (Yes mr t I changed glues lol)
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
willie
#30 Posted : 22 September 2011 20:55:36
this planking is a lot easyer than the victory's
#31 Posted : 22 September 2011 21:02:45
Hi sean.
Looking good so far mate.
ref the planking side of the model, my first go at planking a model was the hatchette bismarck also done radio controlled. i did not have to many
problems with this, following mag instructions. Plus the bismarck was double planked.
once it was sanded and a bit of wood filler here and there gave it a very good finish.
Hope this helps, Ian Cool
Tiswas
#32 Posted : 22 September 2011 21:52:23
willie wrote:
super glue gives you one chance the glue i am useing is NO MORE NAILS EXPRESS pva is weather proof gives a strong bond in 5 to ten minutes full cure in 24 houres and its cheaper than super glue
I too have bought this in readiness for when I start my build which wont be for a while yet. It states on the label that it is 'weatherproof', which is different from being 'waterproof'. Will have a look at their website just to see.
TIS
willie
#33 Posted : 23 September 2011 09:24:31
i have built wooden boats plank and plywood be fore water proof clue came out a good coating of sanding sealer and a few coats of dope never had a plank or ply wood sprange on me, more chance of a plank splitting when it drys out natural
#34 Posted : 23 September 2011 10:54:51
TIS
'Weatherproof' is fine, because it is on the basis that joints with it are not immersed in water, but in fact are overpainted or sealed which creates the seal; you must use an appropriate water sealer as previously mentioned, end ensure that the hull planks are glued along their full lengths to each other as well as to the framework.
Tiswas
#35 Posted : 23 September 2011 21:21:58
Tomick wrote:
TIS
'Weatherproof' is fine, becasue it is on the basis that joints using it are not immersed in water, but in fact are overpainted or sealed which creates the seal; you must use an appropriate water sealer as previously mentioned, end ensure that the hull planks are glue along their full lengths to each other as well as being glued to the framework.
Cheers Mr. T.
Will bear that in mind.
TIS
willie
#36 Posted : 24 September 2011 09:46:55
remember the glue in the ply wood is not water proof as we are not useing marine ply as said agood coating in and out of sealing or marine varinish or what you wish to use if sailing
S2ksean
#37 Posted : 28 September 2011 19:43:27
Issue 4
Deck supports on
Deck supports off
That's all finished for now just gotta wait yet another week for the next one lol
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#38 Posted : 28 September 2011 19:51:42
Hi Sean great job, we will all help you with the planking, never fearCool BigGrin
Zeptrader
#39 Posted : 28 September 2011 20:45:28
nice one:)
#40 Posted : 28 September 2011 21:35:46
BigGrin Lookin good m8
10 Pages <1234>»
This page was generated in 0.386 seconds.
