Before i could fit these items i had to make another food locker, which will be located next to the door on the dividing bulkhead. I could only get the dimensions for it when the WC was temporarily fitted with door open, which is why i didn't make it before. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Painted, varnished and pin-washed. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Two sections of treadplate, painted and ready for fitting to cover the rest of the Galley deck. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
WC fitted, door opened. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Toilet and the sack of potatoes fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this weeks update and the Galley is now completed. I've loved adding all the small, human touches to this section of the u-boat. It makes a nice change from building pumps, pipes and valves! Thanks for looking in, have a great weekend and happy modelling! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Lost for words to describe this build. Brilliant. Chris
It is nice to see you really getting bogged down with this update.  Sorry Very nice work. Mark Regards Markwarren (Mark) Admin
Stunning work.... It's the little personal touches you do that makes this build into a true work of art.... Love it.... Regards Alan
Good evening from 'The Dockyard'. So this week i began to fit out the Junior Rates Accomodation Space. The attached photo shows the lower bunk space, with the 'bunk shelves' painted in sky grey. The bottom edge of the lower bunks has been lined with genuine walnut veneer. It makes so much difference working with 'real world' materials rather than trying to paint plastic to look like wood. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next job was to make 6 mattresses. For this i used 0.5mm thick acetal sheet, cut to size to fit the lower bunk space. As before i used real materials to make the mattress covers, in this case, dark brown cotton tape. I cut out 6 sections of the cotton tape, applied double sided tape to each piece and then wrapped them around the acetal profiles. The double sided tape worked a treat. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
This photo shows a quick 'mock-up' with 2 of the mattresses in place and a scrap piece of walnut veneer to show the final finish. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then proceeded to make 3 pillows. Using a small piece of thick card, taken from the cat's food carton  . I cut it to shape and applied a piece of double-sided tape to one side. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Using a thin strip of kitchen towel, cut to the same width as the cardboard, i folded it over several times and then pressed it onto the double-sided tape. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
To make the pillow cases, i used small pieces of cotton sheet, wrapped around the kitchen towel and fixed with double-sided tape. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
One of the crew figures i bought a while ago, made of white metal, was in the sleeping position. I carefully cut away the pillow, painted the figure and the icing on the cake was when i added thin cotton jersey, in grey and glued it over his blanket. It has made so much difference, rather than trying to paint a blanket. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The attached photo shows a quick 'mock-up' showing the sleeping crew member. This picture shows, with a little bit of thought, how 'real materials' can bring a model to life. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Great imagination and skill there, Phil. The pillow and blanket are brilliant. Keep it coming. Chris
I then turned my attention back to the bunk space and fitted more walnut veneer. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The same part, test fitted into the U-boat. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (8)
